1970 DT1-CM is back
- SwormTours
1970 DT1-CM is back was created by SwormTours
Yamaha DT1-CM matching number engine and frame. It does have the GYT pipe with it. For those in the know, this is a rare bike. According to info on the cyclechaos page, it was only made in the latter half of 1970 and had more torque, +7HP and tighter ratio in gears 1-3. The serial number is in correct zone. Pipe is worth nearly $500 by itself. I am aware that the air box and front fender set up are the hardest to find. It is missing the stator and flywheel but does turn over freely. Will let go for $1000. You can call or text me 97zero-2zero8-5zero52.
No title. Located in southern AZ and I can meet any shipper right off I-10 near Benson, AZ. This will be cross-posted in other groups, forums, craigs etc. If no takers, it will be parted out down the road when I can get to it.
31 Jul 2021 16:27
- Swoop56
Replied by Swoop56 on topic 1970 DT1-CM is back
The cylinder and head are stock enduro parts rather than GYT / MX kit parts .
31 Jul 2021 17:22
- asco
Replied by asco on topic 1970 DT1-CM is back
I guess I can tell you - that there probably are no taker’s here on YE FORUM. We’ve seen it on FB. There’s just not enough bike.
Yeah’ I’m the chosen member “to give you the news,”
“you’ve got a parts bike there’”
and quite possibly you’ll have better luck piecing it out.
It’s like asking 4000 experts how good is this?
best of luck
Sincerely,
asco
best of luck
Sincerely,
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
01 Aug 2021 06:53
