68 DT1 voltage regulator
  • tvrc18
  • tvrc18's Avatar Topic Author
68 DT1 voltage regulator was created by tvrc18
What are the best options for a replacement voltage regulator to replace the stock unit. Pretty sure mine is bad because all bulbs are blown and it looks kind of crispy. It is not available from Yamaha anymore so aftermarket seems the only choice.
29 Jul 2021 05:01 #1
Replied by Gr8uncleal on topic 68 DT1 voltage regulator
Pretty sure that voltage regulators weren't fitted as standard to those bikes. If you're looking at a small item with one red and one white wire, then that is the rectifier. Maybe post a photo or two.
Yamaha did subsequently advise fitting a single wire 6v voltage regulator (see Service Bulletin in the Tech Library) and these are available used (original Yamaha) or new (pattern).
I think that DEET makes a three wire regulator, but I will leave it to him to advise the ins and outs of this.
29 Jul 2021 05:31 #2
  • tvrc18
Replied by tvrc18 on topic 68 DT1 voltage regulator
I did mean rectifier. It does have a red and believe white wire.
29 Jul 2021 10:26 #3
New ones available quite cheap on fleabay (part number 315-81970-61).
Probably best to fit a voltage regulator as well.
29 Jul 2021 10:40 #4
