Are DT and RT autolube pumps the same?
  • type one
  • type one's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Are DT and RT autolube pumps the same? was created by type one
Hi Guys
as it says above are there any differences to 68-70 DT to RT autolube oil pumps??
cheers
T1
DT1's mainly -
1968 AUS
1969 B scabby track bike
1969 B MX project
73 CT3 project
BMW GSA 2018
13 Jul 2021 09:16 #1
Replied by msavitt on topic Are DT and RT autolube pumps the same?
as a unqualified hack up I would refer you to Partzilla to see if part numbers are same!
13 Jul 2021 09:52 #2
Replied by rsteve56 on topic Are DT and RT autolube pumps the same?
The worm gears are different. DT1 uses a 214-13175-01 RT1 uses 275-13175-01.
13 Jul 2021 10:30 #3
Replied by MarkT on topic Are DT and RT autolube pumps the same?
Yes, and just to be clear the internal gear is different to match the different worm shaft.
13 Jul 2021 10:48 #4
  • type one
  • Platinum Member
  • Platinum Member
Replied by type one on topic Are DT and RT autolube pumps the same?
Thanks guys good info !!
Does anyone do a refurb kit for theses as my 360 unit is leaking ??
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
Last edit: 13 Jul 2021 12:39 by type one.
13 Jul 2021 12:30 #5
Replied by Swoop56 on topic Are DT and RT autolube pumps the same?
I'm pretty sure you'll find Yambits do a kit .
They do one for an RD 400 which i've seen when trawling their site , and I'm pretty sure I
saw one for a DT1 , which is quite possibly the same kit as an RT1 .
13 Jul 2021 14:16 #6
  • type one
  • Platinum Member
  • Platinum Member
Thanks I shall check yambits
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
13 Jul 2021 14:18 #7
Replied by asco on topic Are DT and RT autolube pumps the same?
If I remember correctly the DT1 is coded black oil pump.
If I remember correctly the RT1 is coded green oil pump.
This information was read on the report from Yamaha regarding oil pump flow rates.
I’m going to have to say;
no they are not the same.
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
13 Jul 2021 15:07 #8
Replied by yamayeeha on topic Are DT and RT autolube pumps the same?
Someone posted this before, might have been Mark T? Anyway has great info on page 2 to work out differences.
Last edit: 13 Jul 2021 15:15 by yamayeeha.
13 Jul 2021 15:09 #9
 Testing 123  Testing 123
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
The following user(s) Liked this Post: type one, swm
Last edit: 13 Jul 2021 15:17 by asco.
13 Jul 2021 15:12 #10
