1971 Yamaha AT 1 ...runs with pilot screw all the way in.
  • mpritch41
  • mpritch41's Avatar Topic Author
So I finally have the 1971 AT 1 running.
cranks easy idles smooth. Revs quickly...but only with airscrew turned all the way in. If I adjust it out at idle even 1/2 turn it dies.
It will crank up but bogs at 3-4k.
​​​​​​so I'm thinking lean. Standard jet is #30 ( and I have tried that) now have #35 in.
main jet is#150( tried #160 and ran worse) and I have needle clip on lowest position after trial and error.
Plug looks rich.
Checked for airleaks around carb etc.
Carb is clean. Timing is correct.
​​​​​​compression feels adequate.
so with the screw all the way in...runs clean to 3k...sputters 4-6 k then revs on out.
  Any other ideas?
21 Jun 2021 06:26 #1
Did you replace the flywheel side crank seal in the end?
Might be worth doing a leak down test, there are a couple of current threads running about the process.
Experts will be along later to help you, I'm sure.
Yamaha CT3 (in bits)
21 Jun 2021 09:21 #2
in my unqualified opinion I suspect either a plugged primary circuit or an air leak.
The following user(s) Liked this Post: Mothersbaugh, RT325, asco
21 Jun 2021 09:25 #3
  • mpritch41
Yes...replaced all seals.
21 Jun 2021 17:56 #4
