Piston options Dt1 250
Piston options Dt1 250 was created by Ace_1
Just wondering what the differences are between the early piston port pistons as opposed to the 74 and later pistons?? Wiseco does a 74 later kit.
15 Jun 2021 19:57 #1
Replied by MarkT on topic Piston options Dt1 250
Biggest issue is windows in skirt.
Check with Enduronut. He likely has what you need. Or post here and someone else might.
15 Jun 2021 20:04 #2
Replied by RT325 on topic Piston options Dt1 250
& even biggerer issue is gudgeon height difference.
16 Jun 2021 00:23 #3
Now i'm sitting up & taking notice. Tell us more about ya bike. I expanded your pic & looks great in action. Tank looks RT2. What cylinder are you running, a piston port DT1mx cylinder or a DT1 GYT race kit chrome cylinder "like i stuffed running wrong ring against chrome, doh!!" Or did you port your original cylinder. If its a borable cylinder what size are you after, 70.?--i'll go searching.Sorry for the annoying questions. One more, where are you situated--i'm in NZ & see mud in the pic so looks like home to me.
16 Jun 2021 00:38 #4
!mm "4th over in the first link.
Std one in the second
Couple of others but don't have rings which might be near impossible when it come to 6th over 1.5mm in one link
First over single rin DT1MX in last link but once again no rings. I see that one has K for keystone on top & by memory the rings from a two ring DT1 piston fit, so you end up with a spare ring. My memory a bit erratic thinking back50 years so double check!!.
Have a DT1MX cylinder on a tat bike relic of mine, although running a 360 crank just to confuse things but man it goes well. Must be 280cc or so--70x70. Ok, enough Bull S--.
16 Jun 2021 01:01 #5
sorry thought just links would come up, not take up lots of room.
16 Jun 2021 01:02 #6
