1969 AT1E footrest bolts
- whs386
1969 AT1E footrest bolts was created by whs386
In search of the bolts (912-02200-18-00 replaced by 97027-08018-00) that hold the foot rest assembly to the frame for 69 AT1E. I sheared one off when I removed it last week... they seem unavailable everywhere (unsure why??). Anyone have a good source, or what the dimension of the bolt may be? Or where I could look to find out the dimensions?
17 May 2021 12:00
Replied by Gr8uncleal on topic 1969 AT1E footrest bolts
Are you certain of those part numbers? I only ask because CMSNL shows the part number as 97021-10018 (assuming I'm looking at the right part!).
Anyways up, often the dimensions of a screw and bolt are shown within a part number. If the last five characters are "10018" then it is a M10 bolt, 18mm long. If "08018", then a M8 bolt, 18mm long.
Hopefully there is enough left of the sheared off one for you to measure the diameter, for confirmation.
17 May 2021 12:20
- whs386
Replied by whs386 on topic 1969 AT1E footrest bolts
Thank you for that, could be why I can’t find one! I’ve attached screenshots from the parts manual that I downloaded from this site, showing the part as 912-02200-18-00
Partzilla has it as 970270-10018-00
I do see CMSNL showing the one you mention. I’ll measure tonight when home from work. Any ideas with thread pitch? 1.25?
17 May 2021 12:42
- whs386
Well, clearly I can’t read and partzilla has the number as 97027-10018-00 (instead of the one I typed above)
I measured the other bolt I had for the footrest and it came to 10mm. I had an M10 bolt x 1.25 pitch I use to remove the armature and it threaded in nicely. M10 it is, length 18mm.
that being said, is there a difference between 97027-10018-00 and 97021-10018-00? Still same size bolt. Just different model years?
17 May 2021 17:33
Replied by MarkT on topic 1969 AT1E footrest bolts
I'm pretty sure the 5th digit on a bolt is the plating type so functionally no difference... appearance might be different.
The following user(s) Liked this Post: whs386
17 May 2021 20:20
Yes, my understanding of the 5th character in the first block of five is the same as Mark's - I just wish I could find a schedule of what number relates to what finish!
I would suggest that the part number in the original manual of 91202-20018 is a typo (surely not, I hear you all cry!).
- dieseldoc
Replied by dieseldoc on topic 1969 AT1E footrest bolts
Are you still looking for some footrest assembly bolts? I have a couple of good used ones you can have. 10mm dia x 1.25 pitch x 18mm long. Free, just pay postage. My location is Scotland. UK
The following user(s) Liked this Post: Rick C., whs386
21 May 2021 01:39
- whs386
Thanks dieseldoc, but I managed to get some on Ebay already.
22 May 2021 11:28
