1970 CT1 air filter replacement -
  • EnduroDan
  • EnduroDan's Avatar Topic Author
1970 CT1 air filter replacement - was created by EnduroDan
I have the stock filter in there now that's really old but seems to be working.  I would like to keep it stock but I can't locate a new air filter and I'm thinking they aren't available.  Is there a foam substitute, or does the whole air filter unit need to be changed out?  Thanks in advance.
29 Mar 2021 17:36 #1
Replied by JGersh on topic 1970 CT1 air filter replacement -
Dave Kolbo @ KDI makes the exact replacement filter for your CT1
www.kdirepros.com/Air-Filter-p/248-14451-00.htm
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
29 Mar 2021 17:49 #2
  • EnduroDan
Replied by EnduroDan on topic 1970 CT1 air filter replacement -
Thank you! Right now I'm in a wrestling match getting the air cleaner joint and air cleaner on to the carburetor throat and am losing badly. I wonder if I slotted the air cleaner joint in two places if it would be a little more cooperative.
29 Mar 2021 18:33 #3
Replied by MarkT on topic 1970 CT1 air filter replacement -
My guess is slotting would ruin the boot.
Try putting boot in hot water a few minutes and trying to install when warm.
29 Mar 2021 19:27 #4
As Mark T said I would avoid cutting the boot as this may lead to other issues.  You might also try rejuvenating the rubber boot with a rubber restore product.  This will restore elasticity to the old rubber.
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
29 Mar 2021 19:32 #5
As a side note, Yamaha issued the attached service bulletin changing the filter element from paper to foam.
My original showing the remains of the foam (not paper) filter
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
Last edit: 29 Mar 2021 20:35 by JGersh.
29 Mar 2021 19:35 #6
Replied by Swoop56 on topic 1970 CT1 air filter replacement -
Gersh has already mentioned KDI doing the replacement Air Filter element
for your bike .
They also do a replacement rubber boot between the air box and carb .
A worthwhile replacement for old hardened and shrunk originals .
The cost is justified by getting rid of the grief involved with old hard parts .
30 Mar 2021 12:53 #7
