DT1E head with groove???
  • msavitt
  • msavitt's Avatar Topic Author
DT1E head with groove??? was created by msavitt
Check out what appears to be an oring/copper wire groove?  No ring found, just standard copper head gasket.  Any advice on what this grove is for and proper reassembly appreciated.
08 Mar 2021 08:45 #1
Replied by bart.ives on topic DT1E head with groove???
That is normal. Head Gasket should have a corresponding raised ring if it is single layer gasket. Multilayer head gaskets may not have the ring. I have used both. The single layer is first design, multilayered gaskets came later and reduces compression by a little, but may hold seal better.
Be Happy!
08 Mar 2021 09:51 #2
  • msavitt
Replied by msavitt on topic DT1E head with groove???
thank you for the info!
"Be Happy" is great advice, same to you sir
08 Mar 2021 10:09 #3
