DT1 Cylinder-Carb Mounting Bolt Question
- swm
DT1 Cylinder-Carb Mounting Bolt Question was created by swm
The carburetor mount studs were shortened after carb manifold was trimmed to half thickness when 30mm carb was installed. I plan to put bike back to original configuration with 26mm carb & OEM carb manifold.
Threaded studs are not shown on parts diagram, does anyone have a source for "normal" length carb mount bolts?
18 Jan 2021 19:40
Replied by MarkT on topic DT1 Cylinder-Carb Mounting Bolt Question
18 Jan 2021 20:39
- swm
Replied by swm on topic DT1 Cylinder-Carb Mounting Bolt Question
Mark,
I never thought to check air cleaner diagram.
THANK YOU!!
THANK YOU!!
19 Jan 2021 13:01
- yamayeeha
Replied by yamayeeha on topic DT1 Cylinder-Carb Mounting Bolt Question
Just wondering with the GYT/MX head - with increased compression,has the cylinder been ported? Might run better with something bigger than standard?
19 Jan 2021 13:37
- swm
Haven't removed head & cylinder yet for closer inspection, I thought interesting PO installed most of the "go fast" options but didn't change cylinder. I'm going back original with this 68 dt1 including lights, etc., but the next 68 in queue will get all GYT bits.
19 Jan 2021 14:09
- yamayeeha
Nice to have the yam 30mm carb for a gyt kit. You probably have the attached, anyway if not, it might give you clues to (if ported) what has been done or not.
19 Jan 2021 14:26
This message has an attachment file.
- swm
yamayeeha,
Just read your Penny-Wise DT1 Performance article - an interesting and enjoyable document from back in the day.
Thanks,
swm
20 Jan 2021 13:54
- Swoop56
Replied by Swoop56 on topic DT1 Cylinder-Carb Mounting Bolt Question
The Article was lifted from a Popular Cycling magazine . Do you know what Issue ?
20 Jan 2021 15:25
- yamayeeha
I downloaded from the web and think it is July 70 - I enjoy all these old articles too.
20 Jan 2021 16:17
