CT1-C Driven gear and clutch housing
  • Pete-RT1
  • Pete-RT1's Avatar Topic Author
  • Platinum Member
  • Platinum Member
CT1-C Driven gear and clutch housing was created by Pete-RT1
Can anyone confirm that the radial play/take-up in this primary driven gear and clutch housing looks ok.
I understand from the manual that there is a shock absorber consisting of rubbers between the two, but as I've never seen one in the flesh so to speak I thought I'd check with you experts before I put it back together.
Cheers, Pete
Yamaha CT1 007
Yamaha CT1-B The Doppelgänger
12 Jan 2021 09:28 #1
Replied by RT325 on topic CT1-C Driven gear and clutch housing
On the CT2 we used to fit Oring 15 over the gear & into the gap between basket & gear to dampen out the movement. Should work on CT1 except i thought your gear looked larger than the drawing in the parts pic for CT2. don't confuse it with No6 which is the ring i throw away as help a weak clutch to slip. On CT2 & 3 they used to chatter mostly due to a lighter mag flywheel & a racehorse ported motor compared to a docile CT1. CT1 used to idle nice with mild porting & heavier flywheel. So back to the question--yours looks good so put it together & she'll be fine. They can get a lot more play than 'that' in which case i'd fit the Oring--actually a tapered shape on the underside by memory so it fits down in the gap a bit. Mind you it's been close to 50 years since i've done one lol so might've been just a fat round Oring. Chatter was only at idle, well only noticeable at idle.
www.partzilla.com/catalog/yamaha/motorcycle/1972/ct2/clutch
Last edit: 12 Jan 2021 14:56 by RT325.
12 Jan 2021 12:30 #2
  • Pete-RT1
  • Platinum Member
  • Platinum Member
Replied by Pete-RT1 on topic CT1-C Driven gear and clutch housing
Thanks Morley, I knew you would know :likey
Yamaha CT1 007
12 Jan 2021 14:27 #3
Not to be confused with No6--not 5 as i put, not focusing lol, changed it. cheers.
12 Jan 2021 14:57 #4
