1968 DT1 tank change
- yamahahaha
1968 DT1 tank change was created by yamahahaha
Sorry I could not locate this info but at what production number (vin #) did the DT1 tank switch to the puck mount??
02 Jan 2021 19:28
- HouseofEnduro
Replied by HouseofEnduro on topic 1968 DT1 tank change
I believe 13000
02 Jan 2021 19:33
- yamahahaha
Replied by yamahahaha on topic 1968 DT1 tank change
Found it 13000
Thanks you beat me to it
- JGersh
Replied by JGersh on topic 1968 DT1 tank change
Here’s the tank change bulletin...
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
The following user(s) Liked this Post: Badger52, JayB, 68DT250
02 Jan 2021 22:10
- mdscott
Replied by mdscott on topic 1968 DT1 tank change
Dang, the bulletin says replace as a set, which includes the frame.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
03 Jan 2021 16:57
- Rick C.
Replied by Rick C. on topic 1968 DT1 tank change
So yeah.... what's the hold up??
The following user(s) Liked this Post: JGersh, nhsteve
03 Jan 2021 22:18
- bart.ives
Replied by bart.ives on topic 1968 DT1 tank change
Actually the tank mounts and tank for the new designed fuel tanks and mounting was easily mounted to the frames of the 1968 DT1's that used the strap mount. Simple bolt on procedure. So now everyone understands that just because the tank has the puck mount does not mean it was not a 1968 fuel tank. As the bulletin was published in 8 Nov 1968 surely tanks were manufactured and made available prior to publishing the bulletin!
Be Happy!
04 Jan 2021 05:42
Replied by MarkT on topic 1968 DT1 tank change
Interesting. I've never seen Yamaha (or anyone else) offer "bolt on" mounts to convert to the puck-style tank?
DEET did a tutorial years ago on modifying automotive freeze plugs to replace damaged or missing frame mounts.
04 Jan 2021 08:01
- 68DT250
Replied by 68DT250 on topic 1968 DT1 tank change
This has been really interesting and solved a big issue for me.
I have an early s/n DT1 but with the tank mod and I wasn't sure of its authenticity and so was considering trying to re mod back to the stay fixing, but this article has given clarity as to why the change.
Mine has the original frame s/n matching the engine number but has the puck holders welded to the frame and the cable carrier on the rhs, under the tank, has been removed (another mystery solved) to allow the tank to slot on not drop on.
- nhsteve
Replied by nhsteve on topic 1968 DT1 tank change
There is at least one service bulletin, that may be available elsewhere on this site (parts manual maybe??) that alludes to this "fix". Actually, I think it references a whole new frame. It may indicate a starting serial number. Is it possible that your bike has been 'restored' by someone previously? I could vision a scenario where the original tank was unusable, and this was a viable alternative.
Sorry, did not realize this had all been addressed before I wrote!
