Can't Find Rear Sprocket
- Gearboy
Can't Find Rear Sprocket was created by Gearboy
Each place I've tried without any luck. Need stock 45 tooth rear sprocket for CT1B. Any ideas? Thanks!
1970 Yamaha CT1B
1976 Bultaco Sherpa T 183
1980 Bultaco Sherpa T 199A
1996 Suzuki DR200
2015 Yamaha SR400
2023 Honda Super Cub
2012 Suzuki TU250
1996 Suzuki DR200
2015 Yamaha SR400
2012 Suzuki TU250
08 Dec 2020 07:21
- apex
- Content Contributor
Replied by apex on topic Can't Find Rear Sprocket
There's an NOS one from Thailand on eBay for $149.88 shipped! Outrageous!
NOS sprockets are getting harder to find, but there are plenty from other manufacturers, like this:
Allrighty Then
08 Dec 2020 07:27
- Gearboy
Replied by Gearboy on topic Can't Find Rear Sprocket
Thanks for the quick reply, but it seems everyone is out of the stock 45 toother.
1970 Yamaha CT1B
1996 Suzuki DR200
2015 Yamaha SR400
2012 Suzuki TU250
1996 Suzuki DR200
2015 Yamaha SR400
2012 Suzuki TU250
08 Dec 2020 07:34
Replied by MarkT on topic Can't Find Rear Sprocket
Thread below has a lot of good info... actually there are several threads on the topic here.
Or here's a link to what I think you're looking for...
yamaha-enduros.com/index.php/forums/1972...rear-sprocket#104791
Yamaha "recycled" parts over many models and years... that might be why so many bikes and parts are still around.
All the 175's from 1969 to 1981 had the same rear sprocket bolt pattern and pilot hole.
The earlier bikes have the "cush drive" rear wheel hub that requires a sprocket with a relief machined into it on the hub side to get it to line up.
"Industry Standard" rear sprocket number for the "cush drive" 175 like the CT2 is 7032-XX where the XX is the number of teeth you want. Any good sprocket manufacturer should be able to use that number to get you the right sprocket.
P.S. The monoshock 175 428 sprocket without the required relief is 7033-XX. So don't get a 7033.
- Gearboy
I ended up getting this one. I made a bunch of phone calls and couldn't find anything.
1970 Yamaha CT1B
1996 Suzuki DR200
2015 Yamaha SR400
2012 Suzuki TU250
1996 Suzuki DR200
2015 Yamaha SR400
2012 Suzuki TU250
08 Dec 2020 14:02
