Wanted CT2/3 motor
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Wanted CT2/3 motor was created by AirborneSilva
I'm searching for a CT2 or 3 motor, really only interested in a good bottom end.  I don't need clutch or magneto but do need transmission and probably kickstart gear.  Thanks!
19 Apr 2026 09:18 #1
Replied by MarkT on topic Wanted CT2/3 motor
Assembled cases?  Or just the "guts"?
19 Apr 2026 09:28 #2
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic Wanted CT2/3 motor
Hi Mark, really looking for something assembled.  I'm having a major issue with the darn kickstart and idler gear.  I've tried changing right side case half but it's still catching and now I've spent enough money on it so I'm just looking for a complete good bottom end that I can put my clutch, top end and mag on it.  This darn bike is turning into a money pit to the inth degree!
19 Apr 2026 09:31 #3
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Question for you Mark, I found a complete CT1 motor, will that fit in my frame and can I use the top end of my CT2? Thanks
22 Apr 2026 09:25 #4
Yes.  Just make sure it's a CT (magneto crank end with nut and external threads) and not an AT (generator crank end that uses bolt and internal threads))
The following user(s) Liked this Post: Rick C., Ht1kid
22 Apr 2026 14:08 #5
  • AirborneSilva
  • Platinum Member
  • Platinum Member
The vin shows it as a CT1 Here's the ad:   CT1 motor
Last edit: 22 Apr 2026 14:54 by AirborneSilva.
22 Apr 2026 14:48 #6
That's a CT1.
23 Apr 2026 07:36 #7
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks Mark, I went ahead and ordered it. On another note, I bought another CT2 yesterday, they only thing that's missing off it is the air cleaner box and the rear brake spring and connecting rod, other than that it has all lights w/turn signals that all work.
23 Apr 2026 12:44 #8
Replied by tsmitty1958 on topic Wanted CT2/3 motor
After rebuilding 3 CT3's I wouldn't think you need a new motor. Both the items you mentioned, I have fixed with used parts. And 1 of the 3 is a money pit but I think I'll get my money back (not labor).
Don't give up on what you have. Beleive me, I've been where you're at but some things can't be rushed.
Ts
23 Apr 2026 15:18 #9
  • AirborneSilva
  • Platinum Member
  • Platinum Member
I'm not confident in splitting cases and then getting them back together but will try it soon.  I've had this one in the shop twice, when I get it back it works fine for a very short time then it doesn't...  Same issue, we (they) tried different fixes but same result, this motor is cursed.  I have a CT1 motor coming that I'm going to put my new CT2 top end on and drive on...
24 Apr 2026 03:44 #10
