Key not staying in ignition. - 1969 DT1
- Quartermaster35
Key not staying in ignition. - 1969 DT1 was created by Quartermaster35
Just curious if anyone has ever dealt with their key not staying in the ignition..........
Obviously, mine is rusty and sat outside for an extended period of time. The key comes out on all three positions. I sprayed some penetrating oil in it hoping that the springs etc are stuck, but no luck so far.
(Hoping I can keep my original unit)
Any advice would be appreciated.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
30 Nov 2020 08:19
Replied by Gr8uncleal on topic Key not staying in ignition. - 1969 DT1
Common problem - I once lost one out of our RD200 whilst riding along and didn't notice until I got home!
Now I just turn on ignition and stick the key in my pocket.
I read on another forum of someone dismantling their ignition switch and managing to fix the problem, but that's beyond my abilities!
30 Nov 2020 08:27
- Mothersbaugh
Replied by Mothersbaugh on topic Key not staying in ignition. - 1969 DT1
The switch itself is easy enough to open up and clean. The trick is either remembering how it came apart, or taking a number of pictures as it does come apart, so that you can get it back together properly. It's possible to reassemble it more than one way, and then you have things lighting up when they shouldn't and you windshield wipers going on automatically every now and then.
30 Nov 2020 11:21
