Oversized pistons
- RALPH
Oversized pistons was created by RALPH
Are oversized pistons available for 1970 360?
22 Nov 2020 09:12
Replied by Gr8uncleal on topic Oversized pistons
Yes.
Check out CMSNL, Partzilla etc and/or the parts manual in the Tech library here for the part number. You can then post a request for what you're after here, search fleabay or CMSNL (they have three of the four over sizes in stock) and Partzilla for them.
You will need the correct rings to go with them and it's good practice to also replace the top end bearing, wrist pin and the two clips.
Find an engineering shop that is familiar with re-boring Yamaha two strokes. Also, before buying any parts, show the cylinder to the machine shop and get them to advise which over size you need (deep score marks might not come out with just one size up).
When buying, go with the size that is stamped on top of the piston (0.25, 0.5 etc), not what is shown on the box it comes in. Also make sure that you buy a 360 one, not 250 - some sellers say that the same piston fits both!
The following user(s) Liked this Post: Enduronut, MarkT, RT325
Replied by RT325 on topic Oversized pistons
What size is it on now, if not standard 80mm. Look on Ebay but be careful of sellers peddling reed holed pistons as RT1 pistons which have 'no' holes. Yamaha still ran RT1 engine prefix up to RT3, & RT2 & 3 have reed holes. Hope that's not too confusing. Confused myself lol.
22 Nov 2020 15:22
- RALPH
Replied by RALPH on topic Oversized pistons
It's marked 8100, and slightly sloppy.
22 Nov 2020 16:58
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=372872650896&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by MarkT on topic Oversized pistons
Always a good idea to check with Enduronut when looking for a piston.
DEET might possibly have something too.
23 Nov 2020 06:02
- nhsteve
Replied by nhsteve on topic Oversized pistons
Good advice there!
25 Nov 2020 10:57
