Axle Spacer Flange
- Phils2888
Axle Spacer Flange was created by Phils2888
I just got new spacers from Yamaha 93210-42101 for my 1970 250, and they are much smaller than the original. Actually the rear hub did not have any flange, so I only have one original flange from the front hub. Take a look at the size difference in the originals and the “replacements”. I’m not sure if they will even fit on the spacer and since they are much smaller on the outside diameter, will they really do any good in that hub void.
29 Sep 2020 17:57
- apex
- Content Contributor
Replied by apex on topic Axle Spacer Flange
93210-42101 with the -00 on the end is an o ring, #11 in the diagram. I don't see another part with a 93210 prefix, and I don't recognize the part you need in the photo. What # in the diagram is it you need?
Allrighty Then
29 Sep 2020 18:12
- DEET
- Moderator
Replied by DEET on topic Axle Spacer Flange
Free tip..... use an o-ring or two.
29 Sep 2020 20:42
- Phils2888
Replied by Phils2888 on topic Axle Spacer Flange
Ok, I typed the wrong part number in, My apologies but my photo had the correct Part number for the flange, 146-25116, which would be part#8 in the illustration but is cut off in your picture.
30 Sep 2020 04:45
