69 AT1 spark plug replacement for B-8E
  • mtalley11
  • mtalley11's Avatar Topic Author
Replied by mtalley11 on topic 69 AT1 spark plug replacement for B-8E
This is why I enjoy this forum so much. A great write up on the topic and excellent advice based on solid experience.
MarkT, I'll follow your advice and order the cap-off plug and carry a new spare. And, like you say, the compression chamber volume will be reverted back to stock spec. Very likely to help performance and at the least won't degrade it. I did wonder if that second plug might disrupt intake charge flow but never even considered the volume issue.
Lesson learned - don't believe everything you read unless it's from a trusted source. And maybe even someone here besides me will learn something new and benefit from this information. Cheers and happy Labor Day to all. :Buds
07 Sep 2020 15:44 #11
Replied by Bralston on topic 69 AT1 spark plug replacement for B-8E
Jumping on this thread quite a bit later than the original post.  I just picked up an AT1-C though and am looking for plugs.  I know B8ES is the correct plug, however I've come to find out that NGK no longer produces this plug and they are impossible to find.  I took a peak at the plug currently in the bike (from PO) and it is a BR8ES.  The bike appears to run fine with it, but I know that the BR8ES plugs aren't supposed to be used since the AT1 cap already has a resistor in it.
Can anyone help me figure out what to do?  What plugs I should seek out and if it's okay to run the engine with the BR8ES in the meantime?
TIA!
17 Jun 2021 10:40 #12
Replied by RT325 on topic 69 AT1 spark plug replacement for B-8E
Just what i do--I tend to leave well alone if its happy as it is. I'm guessing yours is electric start so 12 volt electrics. Won't be a problem with a resistor plug. If it's magneto then i think i'm running a resistor type in my AT1 & no problem. Someone will tell me but is a resistor to stop electrical interferance on tv's around the village? as when we bucket races --"100cc roadracing--at the local airforce base we had to run resistor everything, caps & maybe plugs too i think. Had to each do a run past the tower before practice to check for interferance or go away & fix it.
17 Jun 2021 16:43 #13
Replied by asco on topic 69 AT1 spark plug replacement for B-8E
I purchased a bunch of NGK B8ES before the stores ran out. Recently' I believe that I sent five or six of those plugs to New York to a customer that was looking for them specifically.
I think they're worth the purchase price plus actual shipping?
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
17 Jun 2021 16:53 #14
Replied by LETSJET on topic 69 AT1 spark plug replacement for B-8E
I bought a bunch of those coveted plugs in Honda packaging ;)
17 Jun 2021 17:18 #15
Replied by MarkT on topic 69 AT1 spark plug replacement for B-8E
I stocked up on plugs too...  but if I hadn't I'd probably just swap to a non-resistor plug cap and run the BR plugs.  Caps just thread on the end of the wire.
www.mikesxs.net/yamaha-xs650-ngk-plug-ca...fh-non-resistor.html
17 Jun 2021 19:00 #16
