Bent axle on AT1C
  • littlemilo
  • littlemilo's Avatar Topic Author
Bent axle on AT1C was created by littlemilo
Dumb question-will a bent axle cause a wobble? I have been chasing a wobble for a few years on this bike, finally checked the axle and its got about a sixteenth inch or more bend in it. Could that be part of it? The wobble gets bad over 40mph, I've tried different wheels, balancing helped a bit, but I'm hoping this axle issue may be my Homer Simpson moment. DOH!
Most motorcycle problems are caused by the nut that attaches the handlebars to the seat
28 Aug 2020 12:00 #1
Replied by asco on topic Bent axle on AT1C
Okay two questions? Front axle? Or rear axle? I have both - if I'm not mistaken from a green 1970 CT1. I might be missing a lock washer or a spacer but that's not something that you would need. This email address is being protected from spambots. You need JavaScript enabled to view it.
if you'd like to buy one at a very reasonable price.?.
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
Last edit: 28 Aug 2020 14:41 by asco.
28 Aug 2020 14:41 #2
  • littlemilo
Replied by littlemilo on topic Bent axle on AT1C
Hey asco, thanks for the reply, rear axle is bent. Haven't checked the front, probably should. I tried straightening it a little and it seems better. Also did more truing and balancing, and its rolling much smoother. I'm guessing this axle has been the main issue all along.
28 Aug 2020 15:47 #3
I will take a look tomorrow. If I have everything for the rear axle, spacers, nut, washer. I will sell it to you for $8.00 + $8.00 dollars shipping if it will fit in a small usps priority mail box. I will also check to make sure that it's true.
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
Last edit: 28 Aug 2020 16:58 by asco.
28 Aug 2020 16:58 #4
  • littlemilo
Sounds good asco, that's more than reasonable. Thanks!
28 Aug 2020 17:33 #5
Replied by Mothersbaugh on topic Bent axle on AT1C
Just curious. Am I correct in assuming the axles do not turn? That the bearings are stationary on both the hub and the axle, and the wheel rolls on the bearings, then? Wondering how an axle bent just that little causes a wobble, then, since it isn't turning.
I'd be more inclined to see if the bearings were seated properly. If one is a bit askew, wobbling, or binding, might result, might it not?
Someone set me straight and stop my wobbling, please.
The following user(s) Liked this Post: Rick C., MarkT, asco, HouseofEnduro
28 Aug 2020 20:00 #6
Replied by MarkT on topic Bent axle on AT1C
Your thoughts are spinning straight and true from where I'm sitting... no wobble detected at all. :Buds
The following user(s) Liked this Post: Rick C., yamahahaha, asco
28 Aug 2020 20:23 #7
Thanks! Now I have to confess, though, that I speak from experience with the bearings binding a bit when not seated square, but for me it was that the axle would not flow through both sides. Didn't get far enough to get to the wobble part of it.
28 Aug 2020 20:42 #8
I have not forgot about you. I will report back tomorrow condition with a picture of the rear axle...
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
The following user(s) Liked this Post: littlemilo
31 Aug 2020 18:53 #9
The rear axle should be delivered Friday ...
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
01 Sep 2020 17:48 #10
