Alternative shocks for RT1?
  • Pete-RT1
  • Pete-RT1's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Alternative shocks for RT1? was created by Pete-RT1
Anyone have any recommendations for replacement rear shocks on a RT1 or are the original dampers serviceable?
Original part number is 291-22210-71.
Yamaha CT3 (in bits)
27 Aug 2020 14:07 #1
Replied by Gr8uncleal on topic Alternative shocks for RT1?
Morning Pete.
I've seen mention of "Redwings", plus one or two others that I can't remember the name of! Maybe search the forum if no-one chimes in.
28 Aug 2020 00:25 #2
Replied by Hammer on topic Alternative shocks for RT1?
Pete-Rt1,
I got a pair of RedWing 'Hammerhead' shocks back in 2012 for $200. They don't appear often, but I found a listing on Ebay today for a set, at $350 for the pair. They were made by a division of Kayaba back in the day. Link is below.
Hammer
www.ebay.com/i/164130119201?chn=ps&norov...wEAQYASABEgKzC_D_BwE
28 Aug 2020 00:39 #3
Replied by apex on topic Alternative shocks for RT1?
darinm mentioned these shocks (link below) in one of his threads. Put them on a CT2 with some modifications needed to the top mount (too wide). The are not expensive!
www.bmikarts.com/Showa-Motorcycle-Shock_p_5405.html?amp=1
Based on his recommendation, I got them, and yes, too wide at the top, and the eyelet bushing sleeves are too small for the shock bolts. I was going to use them on my AT1 restoration bike, but changed my mind as I wasn't sure about modifying the top mount, and how it would look.
Then I got my '71 DT1 and the rear shocks had ze-ro damping. So I grabbed these Showa shocks and did the mod to the top mount and drilled the sleeves oversize, and, they look great! Their damping is just ok for a 200 lb. rider
Allrighty Then
Last edit: 28 Aug 2020 18:50 by apex.
28 Aug 2020 18:48 #4
Allrighty Then
28 Aug 2020 18:49 #5
  • Pete-RT1
  • Platinum Member
  • Platinum Member
Replied by Pete-RT1 on topic Alternative shocks for RT1?
Thanks Apex, they look great.
I'll see if they are available in the UK.
29 Aug 2020 09:08 #6
There's always Hagon here in the UK of course. I've no idea what they're like nowadays, mind.
29 Aug 2020 09:15 #7
Replied by darinm on topic Alternative shocks for RT1?
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=360743774210&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by DTfan on topic Alternative shocks for RT1?
Hi Pete, I'm in the UK too and was thinking about a set of these for my DT3 (Koni) shocks . They're meant for an SR400 but I dont think there would be much difference in terms of damping and the length is almost the same as original.
29 Aug 2020 12:42 #9
Replied by shyted on topic Alternative shocks for RT1?
Is that you Steve ?
Regards Dave .
30 Aug 2020 03:05 #10
