69 AT1 coming home
- LongStride
69 AT1 coming home was created by LongStride
Super excited about my latest find, looks like 69 model serial number 115113 , most of is there, missing carb and airbox, little rusty, I didn't need another project, couldn't pass it up, will post up more pics as I get started on it, gonna be a job just getting it out of that barn
2ET703 Central Texas
The following user(s) Liked this Post: Devin, Noobz
25 Jul 2020 08:22
- asco
Replied by asco on topic 69 AT1 coming home
I have a few correct 248 A2 carburetors ready to bolt on - if you're interested? Best way to reach me my email
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
The following user(s) Liked this Post: LongStride
25 Jul 2020 09:20
- LongStride
Replied by LongStride on topic 69 AT1 coming home
Thanks, I will be needing one
25 Jul 2020 09:28
- LongStride
Probably a couple of weeks before I can get back over there to get it, will post up some more pics when I get it home. pretty excited about getting a first year model AT1, will do a mechanical restoration and get it rideable to start
27 Jul 2020 11:00
- LongStride
Got it home, looks worse out in the daylight, appears to have had a pretty gentle life other than storage damage, did find the airbox cover and filter, but still no carb, looks about 90% original and complete, sadly the engine is stuck, going to give it a much over due bath and take a few more pics
01 Aug 2020 12:01
- LongStride
The following user(s) Liked this Post: t-bone, 2fishkev, Noobz
01 Aug 2020 12:04
Replied by Gr8uncleal on topic 69 AT1 coming home
Gotta keep that logo/cover on the buddy seatpad.
01 Aug 2020 13:23
Replied by MarkT on topic 69 AT1 coming home
I have several AT1 carbs if you can't find yours. I'd sell one cheap if you need it.
01 Aug 2020 14:16
- LongStride
Cleaned up nicely, really surprised how nice the tank is both inside and out,
thanks markT definitely needing a carb, checked my stash and have 2 incomplete at1 carbs, but not enough parts to build one , email is This email address is being protected from spambots. You need JavaScript enabled to view it. , just going to stare at it the rest of the day and enjoy a Shiner beer or three , be pulling it down to see why the motor is stuck soon
The following user(s) Liked this Post: Tex68w, mtalley11, Noobz
01 Aug 2020 15:22
- LongStride
Soaking in oil a few days and got the engine freed up, rings we're stuck, used the heat gun to heat up the piston , was really cool, after 3 heat cycles or so the carbon behind the rings started to boil and shove the rings out, would let it cool down then heat it back up, wished I would have recorded the temperature, then the top ring just popped out and most of the bottom , used a small.pic to dislodge the last part, saved the rings, bore looks great, on standard bore 56mm , light hone and back together she goes
The following user(s) Liked this Post: 2fishkev, Swoop56, darinm
08 Aug 2020 08:45
