Got A Badge Bike
  • apex
  • apex's Avatar Topic Author
  • Content Contributor
Got A Badge Bike was created by apex
Gone through a lot of sticker bikes in the past few years for my street stuff (Suzuki TS250 excluded), but finally, finally have a street (and dirt of course), badge bike!! Stoked!! Thank you to Court, who is a member of the "old" yamahaenduro forum, and didn't make the transition here. Many of you probably know him. He gave me a great deal, the complete '71 (but was apart) and a parts bike '73 DT3. SUPER deal!!
DINNER PLATE!! I'm going to make this sprocket a shot glass holder on an old hub I have. Rotate for shots!
Allrighty Then
The following user(s) Liked this Post: woodman5, Rick C., t-bone, 2fishkev, mdscott, Badger52, KJB, JayB, darinm, Gr8uncleal, LongStride, Pete-RT1, Commando, JHof44
29 Jun 2020 18:35 #1
  • apex
Replied by apex on topic Got A Badge Bike
Got out the SuperClean and the power washer. Looks a bit better.
On to the next usual steps. Spark, verified. Fuel tap removed, and found to be surprisingly clean and the rubber parts were solid. Unheard of!
Carb was also clean, light debris in the bowl, pilot jet was not plugged. So, proceeded to flush & clear, main jet 160, pilot 35. Dumped fuel in the tank, and no leaks yet. Flipped the lever to reserve, and, no leaks yet. fuel flowing into carb...no leaks yet. Choke on, time to kick it! And I kicked...and kicked...only a very occasional burble. Kicked it 60+ times. Choke on, off, no difference. Can hear the slide clunk against the idle stop so it's not seized raised. Spark, air, fuel...timing? Points found to be opening at about the right time, kind of rules out the key being sheared. Kicked it some more, and, nothing. Last resort is ether, and that produced nothing either, just an occasional burble.
Air leak? Pulled the flywheel and stator, and other than the left crank seal looking old original and rubber hard as a rock, it was in place. That will be replaced, but it's OK for a "will it start" test. Reassembled, and decide to set up the pressure test rig. Did that, applied pressure, but couldn't get any. None. By this time it's 10PM, I'm kinda over it for the night, and knew I had a long day the next day (today), so cracked a beer and sat with the wife outside, really nice night in Norcal.
But, I'm still thinking...so got up, walked over and looked at the insulator block. There was what looked like ragged old duct tape on the underside at the cylinder head side. You know, where the grid or screen of the tape is now visible because the coating has aged and fallen off? Pulled off the insulator block, to find this:
Allrighty Then
The following user(s) Liked this Post: MarkT, t-bone, 2fishkev, mdscott, Swoop56, KJB, darinm, Rattrap
02 Jul 2020 23:31 #2
Replied by darinm on topic Got A Badge Bike
Looks like they stored it really well, I'm guessing that was to impede any little critters or moisture getting inside?
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
03 Jul 2020 10:06 #3
Replied by Midlife Motor on topic Got A Badge Bike
Popcorn and soda ready....following this thread. Will be good.
03 Jul 2020 11:43 #4
Replied by mdscott on topic Got A Badge Bike
Plugging the intake is a good idea for storage, it would save a lot of engines getting filled with water.
Apex, be sure to drink your Ovaltine, sorry. I meant to say, be sure to check the exhaust.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
04 Jul 2020 08:06 #5
  • apex
Actually yes I think the bike was stored well, but it was clearly parked outside based on the paint fade. Gas tank is shiny inside too! I've never encountered the intake (or exhaust) taped off for storage, but I can see it being a good idea, if you're parking stuff outside.
It was late when I found the tape, and went out of town for a couple of days, so today was start time. After ALL THAT KICKING I did Wednesday night, of course, it started first kick. Now...time for a cold one! :beerchug :beerchug :beerchug
Allrighty Then
The following user(s) Liked this Post: t-bone, Bigdog302, mdscott, Badger52, shyted, darinm, Pedalcrazy
04 Jul 2020 13:15 #6
Replied by Rick C. on topic Got A Badge Bike
Hey Evan, if you need anything... I got toys for it.
The following user(s) Liked this Post: apex
04 Jul 2020 13:26 #7
  • apex
It starts up. Fine, but I'm not pre-mixing this thing. The oil pump looks to be in remarkable condition, but the sight glass was pushed into the oil tank. Although in better condition than the parts bike oil tank, that also happened to be for a '71 (but on a '73 DT3?), the parts bike oil tank had the window. Therefore, swap it. The parts bike ol tank was filled with 3/4 water, and the rest was a mucky blue/green oil...nasty.
Nice that the bike came with a set of KDI cables! Oil pump cable installed.
And, ran the clutch & brake cables.
Allrighty Then
06 Jul 2020 08:24 #8
  • apex
On to the wiring harness. My intent right now is NO restoration, just assemble the bike, worry about the prettying up later. Most of the harness that came with the bike was missing tape, so after cleaning up I just re-taped it & installed on the bike.
Allrighty Then
06 Jul 2020 08:29 #9
  • apex
Typical birds nest in the headlight bucket. Tested the headlight bulb and it's dead. Anyway, headlight put on for decoration purposes only. Done for now, until new sprocket and chain arrives.
Allrighty Then
06 Jul 2020 08:35 #10
