1971 Yamaha AT1C build thread
Replied by MarkT on topic 1971 Yamaha AT1C build thread
When you say "MX head" do you mean "MX cylinder and MX cylinder head"?
The reason I ask is just using the MX cylinder head on a stock cylinder will give you way too much compression... not a good idea.
25 May 2020 16:41 #11
  • JHof44
  • JHof44's Avatar Topic Author
Replied by JHof44 on topic 1971 Yamaha AT1C build thread
I appreciate the info. I’ll start trying to source an Mx cylinder.
25 May 2020 16:53 #12
  • JHof44
Armature came off with no drama thanks to all the tips I’ve read on this site. Time to replace the seals.
26 May 2020 18:27 #13
Make sure the crank bearing doesn't have play...
Consider using the better IT175 crank seal with proper dual lips to seal pressure and vacuum.
The following user(s) Liked this Post: JHof44
26 May 2020 18:43 #14
  • JHof44
No play in the crank bearing and I did get the oil seal from the IT on order, PN 93103-25125-00.
Now I just need a decent MX cylinder. Found some possible NOS for $400ish, yikes. There's one on ebay with a crack and a bent fin for $300 plus shipping, double ouch.
I'm in no rush though, still have plenty to do. Once I get the bottom end buttoned up I'll move onto the fuel tank. Somebody (my dad) creamed it back around 1991 so I'll need to dedicate some hours to it.
27 May 2020 08:42 #15
  • JHof44
I may just end up going with a 175 top end.
28 May 2020 10:03 #16
  • JHof44
Got it all torn down at this point. I’ll be sending the frame, swingarm, and some other pieces to my brother for sand blast and powdercoat. I will likely start on removing the cream from the fuel tank next, or possibly start rebuilding the suspension and wheels.
01 Jun 2020 16:24 #17
  • JHof44
The free bike just cost me a $500 watch. That’s an expensive learning lesson. Could be worse.
01 Jun 2020 19:54 #18
  • JHof44
I’ve been able to piece together most of my top end. The cylinder head is new old stock but the cylinder needs some work. There’s a surface crack and at least one bent fin so the cylinder will go off to my master fabricator brother to fix that before addressing the bore. I also have a GYT expansion chamber showing up this week.
14 Jun 2020 07:35 #19
  • JHof44
Unfortunately UPS has lost my GYT expansion chamber. They're "looking for it" but I've heard the same thing for a couple weeks now, so I'll probably start looking for other options soon.This really took the wind out of my sails.
I've been trying to reach Racer's Machine to have the cylinder work done but haven't heard back. Might end up sending that up to my brother's shop too, I don't know at this point.
26 Jun 2020 08:46 #20
