Hello From Yama-Land Restoration
  • asco
  • asco's Avatar Topic Author
Hello From Yama-Land Restoration was created by asco
Two bikes will probably get started tomorrow.
Brandy and Ziffle. They both were pressure and vacuum tested. Time Tells No Lies. Thank You MarkT. The Right Crankshaft Seal on Brandy is 3mm’s too tight on the collar. It let loose In Gorman and was replaced. This same modification worked with Elsa 1971 CT1-C.
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
Last edit: 11 Sep 2026 18:25 by asco.
11 Sep 2026 18:19 #1
