decompression cable
- jsmith6752
decompression cable was created by jsmith6752
are the 1974 DT360 suppose to have a cable and hand lever? I don't see either on the bike I just bought....thanks
29 Oct 2024 07:48
Replied by Gr8uncleal on topic decompression cable
Yes to cable, no to hand lever.
The cable goes from the decompression valve into the top of the crank case and is linked to the kick start - ie when you kick start the bike then, if everything working as it should, the valve will open. See link below.
The following user(s) Liked this Post: MarkT, Schu, Ht1kid, Oldbikenut, Gerryz, pahiker
- jsmith6752
Replied by jsmith6752 on topic decompression cable
Thanks for your response. From that information it appears as if mine is working properly. I have not started it yet but I can tell it's working by using the kick starter
29 Oct 2024 11:35
- jsmith6752
Not sure if I am posting this in the correct place but I will try it out. I have a lot of wiring issues. The top of my list is I have a black wire with a green sleeve in my headlight housing.that has 6 volts when the key is on. I can't think of a thing that should have power going it it.???????????
17 Nov 2024 14:54
Moderators: yamadmin, Makotosun, DEET, Vinnie
