1976 Enduro 250 Oil Tank Dissection
- pabdt
1976 Enduro 250 Oil Tank Dissection was created by pabdt
Thought some of you would find this interesting to look at. I was going to use a borescope, but a cut off wheel was more fun!
The goal is to sand blast, metal work, paint in Geneva Green, leak test, then probably give a way. Hopefully its not too far gone.
Is this a 76 250? I think so.
I wasn't aware of this metal supportive structure internally. The metal is thin, so maybe a way to prevent gravity lock from blocking the line w/oil. Docs indicate
autolube does not suck, is gravity fed.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid
Replied by MarkT on topic 1976 Enduro 250 Oil Tank Dissection
Likely a 1975 oil tank... 1976 models only said "Enduro" on oil tank and exhaust shield emblems.
18 Jul 2025 14:26
- pabdt
Replied by pabdt on topic 1976 Enduro 250 Oil Tank Dissection
Just noticed there is a filter by the drain. going to cut away the filter before assembly.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: Snglsmkr, Sneezles61
