Mikuni VM28SS carb alternative for DT250A
  • AXLE1
  • AXLE1's Avatar Topic Author
Hi All
Has anyone know an alternative replacement for Mikuni VM28SS carb  for DT250A. or anyone got a spare for sale?
Regards
Last edit: 14 May 2025 11:51 by AXLE1. Reason: more 2b added
14 May 2025 11:42 #1
Replied by Sneezles61 on topic Mikuni VM28SS carb alternative for DT250A
I have one. Are you in the USA?
14 May 2025 15:48 #2
  • AXLE1
Replied by AXLE1 on topic Mikuni VM28SS carb alternative for DT250A
I am in Scotland UK, thanks for your reply.
14 May 2025 23:51 #3
Replied by Gr8uncleal on topic Mikuni VM28SS carb alternative for DT250A
Is yours damaged, missing parts, or totally absent?!
15 May 2025 03:55 #4
  • AXLE1
yes, it is pilot jet #60 it does look like main jet it is slightly taller and has an O ring on it.
15 May 2025 06:08 #5
The correct carb will have 438 stamped on it, on the flat surface just below the choke lever.
The main jet is in the float bowl, screwed into the banjo bolt in the base.
The part with the 'O' ring is the needle jet setter. Replace the 'O' ring with a genuine Yamaha one (they are still available).
Yamaha DT250 1974 USA CARBURETOR - buy original CARBURETOR spares online
15 May 2025 06:36 #6
  • AXLE1
Hi
Thanks for your reply it has been really exhausting the pilot jet #60 is the item No,1 in the exploded diagram and can not find it on spare line shop. Maybe you could put point this out for me!!!
Regards Axle
15 May 2025 13:08 #7
Here we go.
Motocarb and/or Allens might well have it as well.
Don't be put off by it showing as for TZ - many Mikuni parts were shared between different carbs and bike manufacturers.
Mikuni 60 Pilot Jet. 193-14142-60 Genuine TZ Yamaha. New | eBay UK
Last edit: 15 May 2025 23:28 by Gr8uncleal.
15 May 2025 23:26 #8
Replied by automan on topic Mikuni VM28SS carb alternative for DT250A
or a 360 30mm carb 445-
17 May 2025 08:31 #9
Moderators: Makotosun, DEET
