Carburetor won't fit on Yamaha GT80 (Help)
Replied by Gr8uncleal on topic Carburetor won't fit on Yamaha GT80 (Help)
Are there any numbers stamped into the carb body? They'll be on a flat surface. These might help identify what that carb was originally fitted to.
29 Aug 2024 23:30
#11
- Tinkicker
Replied by Tinkicker on topic Carburetor won't fit on Yamaha GT80 (Help)
That carb is similar to a Dellorto, commonly fitted to the likes of kids Italjets, Fantics, Garrelis ect. The type where there is no airbox, just a mesh and wire wool screen over the carb mouth.
The carb fitted to the TY80 was a clamp on mikuni VM18 and I believe the GT engine is essentially the same as the TY, barring gearing and stator. Certainly looks like it. Seem to remember a plastic sleeve fitted inside the spigot clamp.. Long time ago.
No idea of jetting differences, but that is not hard to research.
Replied by RT325 on topic Carburetor won't fit on Yamaha GT80 (Help)
Ok, one more try. That chinese carb i thought said 15mm, which it does, but when i take screen shot & expand it up the 15mm refers to the venturi size down the end where it steps down at the end of the insulator spacer. Therefore i'd take a guess that the adaptor, insulator bit would be 20mm that you require.
- flaps8
Replied by flaps8 on topic Carburetor won't fit on Yamaha GT80 (Help)
Aliexpess says this carburetor is for Yamaha PW80, which has 20mm intake side, so it supposed to fit. I will order it, and we'll see how it's gonna go.
30 Aug 2024 22:44
#14
