JT2.......Won't go into ANY gear
- yamahahaha
JT2.......Won't go into ANY gear was created by yamahahaha
I went and looked at a JT2 the other day. I was NOT able to find ANY gears using the shift lever. I tried with and without the clutch. I even tried rolling the bike back and forth. It was if there was nothing there at all. NOT even a click of any sorts. My question is " What are the POSSIBLE CAUSES of this ?????
17 May 2023 10:55
- Mini Enduro Man
- Supporting Moderator
Replied by Mini Enduro Man on topic JT2.......Won't go into ANY gear
Rusted Transmission gears or rusted Shift Drum are my educated guesses!!!
17 May 2023 14:39
Replied by RT325 on topic JT2.......Won't go into ANY gear
No chain.
Rear sprocket bolts broken off.
Front sprocket nut fallen off & sprocket moved off the splines.
Main shaft broken.
Output shaft broken .
Neutral is at the top on those so 4 down incase ya thinking wrong.
I had two JT1's back in the day & have a third one somewhere [grandkids].
Main shaft broken.
Another guess. It's landed hard on the left side & popped the circlip & shaft's moved sideways then claw arm has got off the drum pins.
Might be hard for that to happen as probably not much clearance between the gear lever & case/cover to move sideways.
Unless something happened while left case has been off. Could pull hard on the gear lever while moving up & down through its travel & 'might get lucky' & pop back on.
Replied by MarkT on topic JT2.......Won't go into ANY gear
RT325, good guess. I've seen that more than once on the AT/CT with a similar shifter design. Happens easier than you'd think.
18 May 2023 17:03
- yamahahaha
Replied by yamahahaha on topic JT2.......Won't go into ANY gear
I'm hoping to have time tomorrow to do a little investigating
20 May 2023 17:27
