Re:Re:Cylinder head dt1
Replied by MarkT on topic Re:Re:Cylinder head dt1
"No problem with being cautious and asking questions. Measure twice, cut once and all that!"
No matter how careful I measure and cut twice it still comes out too short.
I must be doing something wrong.
13 Mar 2022 09:09
#11
- msavitt
Replied by msavitt on topic Re:Re:Cylinder head dt1
glad you were cautious and got it out!
Mark you make a good point. On cars and bikes with aluminum heads and super long reach I typically apply a very small amount of anti seize to threads
The following user(s) Liked this Post: LETSJET
13 Mar 2022 09:21
#12
- Andrew60
Replied by Andrew60 on topic Re:Re:Re:Cylinder head dt1
Hi I have sent for a cable kit to make up a throttle cable on a dt1 (no oil pump ) it seems after reading members q&a this isn’t goin to be straight foward task !!! Any help or info would e appreciated ! I have the old cable with the one cable in it which leads to the lower cable but no oil pump cable ., thank you
Sent from my iPhone using Tapatalk
20 Mar 2022 13:54
#13
Replied by RT325 on topic Re:Re:Re:Cylinder head dt1
If i'm understanding your post you already run without the pump so nothing changes for you, just one cable from throttle to carb. I won't mention the pump as whatever ya doing it works for you.
If you 'do' have the pump, i think on mine 'without checking' i capped it off & reduced the minimum stroke to zero or less than zero. Even so, if you had no cable around the pump pulley & on minimum stroke i'm sure it would leave enough oil in the pump to lubricate the gears after its stopped pumping constantly. Reducing stroke is easy, just remove a washer or more 'shim' from under the plate to reduce or stop it stroking while capping the line in from the tank. I wouldn't block off at the cylinder doing it like that. Clutch cover off of course to remove pump & shaft & then make a blank off plate if you wanted to go that way.
20 Mar 2022 15:22
#14
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=154441504621&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Andrew60
Thanks for the information much appreciated! I’m having trouble with posting on site ive tried tap & talk maybe I need to update my phone
21 Mar 2022 11:54
#16
