Re:Re:Cylinder head dt1
  • Andrew60
  • Andrew60's Avatar Topic Author
Cylinder head dt1 was created by Andrew60
Hello hope everyone s ok , could I have some input please ! I have a cylinder head & it’s currently has two plugs in which seem to have been there for a long time  I’m scared to remove them & strip threads I’ve been soaking in penetrating oil for a week has anyone any tips heat ? Brute force ? Any advice appreciated thanks again
10 Mar 2022 13:59 #1
Replied by msavitt on topic Cylinder head dt1
stripping the threads unlikely
have you put a spark plug socket and some torque on it?
10 Mar 2022 14:07 #2
  • Andrew60
Replied by Andrew60 on topic Re:Cylinder head dt1
Not at the present !think I will get some penetrating oil (‘plus gas ) & soak some more then try it seems a trivial but I really don’t want to do any damage through being impatient thanks for reply appreciated
Sent from my iPhone using Tapatalk
11 Mar 2022 11:59 #3
  • Andrew60
I was using wd 40 to soak but not penatrating oil apparently
11 Mar 2022 12:01 #4
Replied by RT325 on topic Re:Cylinder head dt1
Must be me but i always think how the hell can oil get in past a thread done up tight. I recon it has to be cracked a bit first to let even the best penetrating oil get in. Bolt the head down to something & swing on the socket. If the plug breaks--its not my fault--is it--Umm. Ok if ya crack it free then use penetrating fluid, soak & work it back & forth. If the thread comes out well--hellicoil job.
11 Mar 2022 14:59 #5
Replied by msavitt on topic Re:Cylinder head dt1
I do not claim to be an expert, but I have been working on small to large engines since I was 14 and I am not almost 57 and have NEVER stripped head threads loosening a tight spark plug.  I think you should put a sparkplug socket on it and apply torque necessary to crack it lose.  If you find it stripped its because that's how it was put together.
just my opinion
11 Mar 2022 16:01 #6
Replied by MarkT on topic Re:Cylinder head dt1
I can understand the reluctance.  Some car engines are allegedly prone to having plug corrode into the aluminum head and threads coming out with plug.  Plus not all plugs have the nickel plating on the threads like NGK and corrode much worse.
Pulled threads seems to happen with high mileage and no maintenance.  If you're really worried, pop the head off, invert it, and use your penetrating oil in the combustion chamber.  On the Fords that had this issue, the recommendation was to slightly loosen the plug and then apply penetrating oil...  but they were conical seat plugs and not gasketed if I remember correctly.
P.S.  I've never had a problem with a Yamaha...  even ones with original plugs that look to have been in place for decades...  but you can see what you have and we can't...
11 Mar 2022 20:16 #7
  • Andrew60
Replied by Andrew60 on topic Re:Re:Cylinder head dt1
Thanks for the reply’s & input I will give it a go later on thanks again
13 Mar 2022 07:26 #8
  • Andrew60
Job done ! Guess I was being over cautious thanks again
The following user(s) Liked this Post: Gr8uncleal, Schu
13 Mar 2022 07:38 #9
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic Re:Re:Cylinder head dt1
"Job done ! Guess I was being over cautious thanks again"
Well done.
No problem with being cautious and asking questions. Measure twice, cut once and all that!
Last edit: 13 Mar 2022 07:50 by Gr8uncleal.
13 Mar 2022 07:50 #10
