DT250 right crankcase
- Enduro nut
DT250 right crankcase was created by Enduro nut
So im in the process of getting ready to paint and install all new bearings and seals on the lower end of my 1975 DT250 when i noticed this chip in the right crankcase where the main bearing/seal sits. My brotheres are welders and i can have them weld this then i can shape it with the dremel. My question is should the right side look like the left? with the hole and all?
11 Jan 2022 07:46
Replied by MarkT on topic DT250 right crankcase
I would leave it alone.
The following user(s) Liked this Post: JGersh, adguy2112
11 Jan 2022 12:11
- Enduro nut
Replied by Enduro nut on topic DT250 right crankcase
Perhaps your right, seeing how that damage is where the bearing goes and not the seal it should be ok i would think. On 2nd thought maybe some JB weld would be a good idea. Ill think on it but chances are ill leave it.
11 Jan 2022 20:05
I might be wrong but nothing goes where the damage is. Bearing fits in the larger OD and seal goes in from the other side and needs to stop before it blocks the hole.
Case may have been that way from the factory?
11 Jan 2022 20:11
- Pete-RT1
Replied by Pete-RT1 on topic DT250 right crankcase
I'd leave it alone. Can't see any detrimental effect of it being there.
Yamaha CT3 (in bits)
12 Jan 2022 00:17
- msavitt
Replied by msavitt on topic DT250 right crankcase
Wouldn’t touch it
12 Jan 2022 01:06
- Enduro nut
Leave it alone i shall! time to get painting and ordering up some bearings and seals. Appreciate all the impute!
12 Jan 2022 07:56
