My 1973 DT3
- bhepp15
Replied by bhepp15 on topic My 1973 DT3
Oofda.. any tips on this?
26 Mar 2022 12:33
#41
- Schu
Replied by Schu on topic My 1973 DT3
I had a similar wheel. I wire brushed it the best I could. Then I brush painted it with black rustoleum. New rubber strip, tube, and tire. Haven't been in there since, so I can't say how it's held up over the years.
- bhepp15
They looked good when you did them! I bought some wire brushes but didn’t seem to do much but I’ll keep grinding at it. Didn’t think about the paint tho
26 Mar 2022 13:00
#43
- Brzn
Replied by Brzn on topic My 1973 DT3
Mine, I used a brass wire cup brush on my cordless drill. Then I scrubbed with WD-40 and a Medium Steel Wool pad. I wiped them down, but didn't completely clean the WD-40 off. New rim strips, tubes and tires.
26 Mar 2022 13:20
#44
- bhepp15
Took wire wheel to it and then applied a little oil to deter future rust. Dumb question now, I cant seem to find chain size in tech library. Does anyone know the chain specs?
28 Mar 2022 08:23
#45
- Tom P
Replied by Tom P on topic My 1973 DT3
I just put this chain on my '71 CT1, and if you have the stock sprockets I believe it will fit yours as well.
Xttps://www.ebay.com/itm/233503750932
Oops, that may not fit the DT3. It looks like you need the Bikemaster 520H chain.
I also have tires and tubes coming this week, so I'll probably have to deal with the internal rim rust as well.
Replied by RT325 on topic My 1973 DT3
Just buy a chain that longer than spec incase sprockets are different to spec & knock a pin out to the length required after you've run it around the sprockets then you'll have a few links spare incase needed later if you go bigger on the rear. 520 chain of course for a 250.
28 Mar 2022 19:18
#47
- bhepp15
Quick question, do you oil/grease wet side crank seal whe
installing? Couldn’t find anything on that while searching on here. Have new plates in oil and going to install everything tomorrow.
03 Apr 2022 21:43
#48
- Swoop56
Replied by Swoop56 on topic My 1973 DT3
I always put grease or petroleum jelly between the seal lips , and a smear of oil on the outer contact area , to aid install .
04 Apr 2022 00:49
#49
- bhepp15
Okay thanks, what type of grease is best to use?
04 Apr 2022 08:41
#50
