Electrolytic Tank Cleaning
  • meadeam
  • meadeam's Avatar Topic Author
Electrolytic Tank Cleaning was created by meadeam
I know I have started other threads on cleaning a gas tank, but one of them is very old and I didn't want to resurrect. The most recent was regarding lining, which I have thus far decided I am not going to do.
My tank seems to be endlessly rusty. I did several cider vinegar baths and got literal cupfuls of rust out of the tank. I had removed all of the loose particles, though the surface still appeared rough and rusty. I fogged with oil beucause it was shelved for several months. Recently I have shaken the tank for 10-15min with sheet metal screws, and rinsed with gasoline until it flowed clean. The inside is still not shiny metal, but doesn't appear too rusty or flaky. I've started running the bike, and it continually clogs the petcock. After maybe 30 minutes of total run time, the inline filter is full of bits of rust. Obviously the tank is not ready.
I think I am going to try the electrolysis route now. Seems pretty straightforward, share your experience if you have any.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
15 Jun 2020 08:08 #1
Replied by LongStride on topic Electrolytic Tank Cleaning
Yes, phosphoric acid is the most common method, get it at hardware store, sometimes it will re-rust, any tank I do now will be the electrolysis method, I use a soultion of sodium carbonate, ( pH increase for pools and spa) and water, a copper wire with a zink plated bolt for the anode, remove and clean the bolt each day, it will dissolve after a week, replace the bolt about half way through, using an old school battery charger with copper windings for the voltage, a week to 10 days to get it right, use a block off plate for the petcock , disolved the petcock internals on the first one, the beautiful thing about this method is that the process etches the metal with black oxide and so far have not had a re-rust
2ET703 Central Texas
Last edit: 15 Jun 2020 10:07 by LongStride.
15 Jun 2020 09:59 #2
Replied by Pete-RT1 on topic Electrolytic Tank Cleaning
Did you feed it after midnight or get it wet?
Yamaha CT3 (in bits)
The following user(s) Liked this Post: 2fishkev, meadeam, Wax, LongStride
15 Jun 2020 13:40 #3
Replied by apex on topic Electrolytic Tank Cleaning
Using a bolt works, but takes a while. I use fence wire that you can buy in rolls at any Lowes/Home Depot/Ace. I cut to length, then wind loops until long enough, then poke through a expandable freeze plug, shaped to a cone to fit and stay put in the tank opening. The longer anode gives you more surface area in the solution and speeds the process.
See post #3 in this forum thread.
yamaha-enduros.com/index.php/forums/1972...ck-c-brown-shoes-at2
Allrighty Then
The following user(s) Liked this Post: 2fishkev, meadeam, LongStride
15 Jun 2020 16:41 #4
  • meadeam
Replied by meadeam on topic Electrolytic Tank Cleaning
I may be the only one who didn't know this, but if your battery charger is "fully automatic" it won't work. It thinks it has been shorted and turns itself off.
So now I need to invest in another battery charger.
I have a spare 12V battery for my FZ6 that is fully charged. I'll try putting that in the loop.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
Last edit: 17 Jun 2020 08:59 by meadeam.
17 Jun 2020 08:49 #5
been wondering about using a battery and modern automatic charger , keep us posted
17 Jun 2020 11:05 #6
Replied by Wax on topic Electrolytic Tank Cleaning
I used an old laptop charger to make my electrolytic cleaner a few years ago. +1 on using wire fence pieces that was my sacrificial material of choice.
Last time used it was for a 2 piece go kart clutch that was rusted together. Took about 2 days for it to free up.
The following user(s) Liked this Post: LongStride
17 Jun 2020 17:29 #7
