Pulsar done - What are my options?
Replied by MarkT on topic Pulsar done - What are my options?
Some people are happy with the Rex system... others have had issues. That might have been more about the early systems? I don't know. If you search you might find more info.
Powerdynamo/VAPE is a good system. Best price is usually buy direct.
Another good option is points system from DT250.
10 May 2020 21:39 #11
Replied by JayB on topic Pulsar done - What are my options?
The VAPE comes with a new flywheel/rotor. As I understand it, there is no keyway in the supplied flywheel and you don't use a key when you mount it on the crankshaft. That means you have to retime it every time you remove/install the flywheel. Possibly you could order it with a keyway or have one cut by a local machinist. Or do without and retime it when you remove the flywheel, which should not be necessary very often since you have a new CDI system and you put in a brand new seal behind it!
11 May 2020 06:41 #12
