Headlight Clip Replacement Trick
  • Yamahamadingdong
  • Yamahamadingdong's Avatar Topic Author
Headlight Clip Replacement Trick was created by Yamahamadingdong
If you replace the headlight on a 74-75 (and others I'm sure) Enduro, you can buy the regular easy to fit headlight....
but I went with a newer halogen lamp + bulb from Octane Lighting: www.octanelighting.com/kit5-3-4-motorcyc...tml?category_id=2948
It fits, but is a little wiggly because it is not exactly right for the housing.
Mine has one clip left (I think there were originally 3), but it didn't work right.
The mystical solution: Binder clips
Just take the metal ends off those black binder clips, pull them apart a little, and shove them under
See photos.
I cracked up when it worked. It's in there good enough to hold it by the plug and shake it around, and push it around trying to get it back into the housing with all the wires in the way!
The following user(s) Liked this Post: MarkT, JayB, HouseofEnduro, Super90
11 Apr 2020 23:23 #1
Replied by Makotosun on topic Headlight Clip Replacement Trick
The headlight clips (good reproductions) are available from MikesXS
www.mikesxs.net/yamaha-xs650-headlamp-w-clips-pk-5.html
The following user(s) Liked this Post: mdscott, yamahahaha
12 Apr 2020 06:37 #2
Replied by DEET on topic Headlight Clip Replacement Trick
Innovative!
And cheap!
The following user(s) Liked this Post: Makotosun, MarkT
Last edit: 12 Apr 2020 06:54 by DEET.
12 Apr 2020 06:54 #3
  • Yamahamadingdong
Replied by Yamahamadingdong on topic Headlight Clip Replacement Trick
Good to know. The only one left in my headlight assembly (if there was ever more than 1), is super rusty and not so springy anymore.
The binderclip idea was discovered when I didn't feel like waiting more time to get this headlight back in. :D
12 Apr 2020 08:43 #4
Replied by MarkT on topic Headlight Clip Replacement Trick
Nice tip! Thanks for sharing! :likey
12 Apr 2020 09:01 #5
