Newbie to the forum
- rsmith56
- Topic Author
Newbie to the forum was created by rsmith56
Have a 73 175 CT 3 and try to restore. Has 325 original miles, but been sitting for 50 years. Replaced tires, fuel valve, brake shoes, fork seals, and chain. Finally got tank clean. Lights and signal lames on and cables lubed and free. Have a new battery. Working on carb now. Has original headlight, cracked, and not sure if it works yet.
Am located in Texas panhandle. Had a 71 175 in high school, so this a nostalgic project.
The following user(s) Liked this Post: Ht1kid, Jogar, Tom P, Crazy Horse 124
16 Apr 2023 12:16
Replied by MarkT on topic Newbie to the forum
Sounds like a great project.
16 Apr 2023 13:01
Replied by Ht1kid on topic Newbie to the forum
Greetings from Tennessee
I have a 71 Ct1c there are a lot of us on the forum who have 175’s
16 Apr 2023 14:00
- Jogar
Replied by Jogar on topic Newbie to the forum
hey from Canada!
I've also got a 73 CT 175.
feel free to reach out with any questions, I'll do my best to help out.
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
16 Apr 2023 18:20
- AirborneSilva
Replied by AirborneSilva on topic Newbie to the forum
Welcome, had a 1972 CT175 as my first bike, would love to get another some day. Lot's of help here if needed.
1975 DT400
1972 DT2 250
1972 JT2
1975 DT400
1972 DT2 250
1972 JT2
17 Apr 2023 02:09
- rsmith56
- Topic Author
Replied by rsmith56 on topic Newbie to the forum
Got carb clean and she runs good. Also got a new battery charged and installed. Headlamp has both beams burning. Sealed the cracked lens with some E6000. Turn lamps all burn but don't flash. Got a rear tail/stop bulb incoming. My neurtral indicator and turn indicator lights burn. High beam indicator does not. Left switch gear has switch broken off. Ordered used one (entire left swithch gear) at a stupidly high price. Should be here soon. Hope it all is functional.
I am sure I will need advice and techinal advice as I go. (read: stupid questions)
17 Apr 2023 18:25
Replied by RT325 on topic Newbie to the forum
My mistake but was reading "Lights Burn" as "Burning Out"--it's just me!!. So they go & glow but indicators don't flash, just glow. Headlight operates without blowing at revs?. Bulb wattage has to match the unit but can go a little higher but not lower--well sometimes you can depending. Like if 8 watt is std then 10 watt will flash faster, Also is it charging back into the battery/motor running, just to be sure its soaking up a charge otherwise headlight is likely to 'blow/burn out' as battery ballances the system. Sorry i'm probably wondering off track.
The following user(s) Liked this Post: Quartermaster35, Jewelkutter, rsmith56
17 Apr 2023 20:39
- Tom P
Replied by Tom P on topic Newbie to the forum
That's awesome! I also had a 1971 CT-1 in high school, and rode it into the ground. My Dad bought two of them in 1971, and the one he rode for a while sat idle with only ~350 miles on it, rusting. A year ago I began working on it, and long story short got it running, and love riding it around town!
The following user(s) Liked this Post: RT325, rsmith56
- rsmith56
- Topic Author
Got the new battery in and new tail bulb, it fired up and everything works. When the new/used switch gear here and installed, l will go for state inspection. Plan to apply for Texas “Classic” tags so as no hassle from the LEO’s.
The following user(s) Liked this Post: Ht1kid, Quartermaster35
18 Apr 2023 11:30
- rsmith56
- Topic Author
Ok, now I need some information/help.
The bike has been sitting for 45-48 years. I have it running fine. Waiting on seat recover, but decided to take it out for a short ride (riding trials style). Ran great, shifts well, brakes good...biike has a little over 300 orig miles....now the problem:
Taking off cold, I was easy on the throttle, short shifting until it warmed up. Then, started applying more throttle, and started to get some clutch slippage from about 2500 rpm and up. Let off and it pulled fine. Rode about a mile. My thoughts are maybe the clutch plated dried out after so much time sitting unused. I ran it on a stand some this evening; disengaging and engaging the clutch to try to see if it "oils up". Is this sound theory or should I just get a new clutch?
thanks,
thanks,
19 Apr 2023 17:16
