1974 DT 125 Kickstarter Issue
  • StukaGruppen13
  • StukaGruppen13's Avatar Topic Author
1974 DT 125 Kickstarter Issue was created by StukaGruppen13
Hello, engine is finally in the bike after a rebuild. However the kickstarter doesn't spring back when kicked down. Could it be I have it in the wrong location, or is it that it has no oil yet? Thanks.
04 Mar 2019 13:36 #1
Replied by MarkT on topic 1974 DT 125 Kickstarter Issue
I would pull the cover and check to make sure it's installed correctly... before putting oil in it.
The following user(s) Liked this Post: StukaGruppen13
04 Mar 2019 13:57 #2
Replied by Mothersbaugh on topic 1974 DT 125 Kickstarter Issue
Ditto. In particular, make sure you have preloaded the spring and inserted the ends in the appropriate places. Check the manual. Probably one in the library, here.
04 Mar 2019 20:39 #3
  • StukaGruppen13
Replied by StukaGruppen13 on topic 1974 DT 125 Kickstarter Issue
I have a manual downloaded to my laptop, but I shall make sure it's installed right. Thanks.
05 Mar 2019 06:05 #4
Post up some pictures of what you find... someone might spot something to help.
05 Mar 2019 06:50 #5
Replied by 2fishkev on topic 1974 DT 125 Kickstarter Issue
I just took my second one down to reseal, so I’m familiar with how things should fit up. Can post comparative pics if needed.
05 Mar 2019 08:07 #6
  • StukaGruppen13
I shall post pics up when I take it apart again. Thanks.
05 Mar 2019 10:51 #7
Replied by RT325 on topic 1974 DT 125 Kickstarter Issue
Unless the splined stop has come off the shaft & been put back on in the wrong position--unlikely. Does the spring hole go right through so you could fit it half a turn out. Or are you accidentally hooking the spring eye onto the wrong thing--which wouldn't be easy just thinking about it. Hope ya get it sorted. Have seen stops come adrift then the kick start moves forward so the owner moves lever back--do that a couple of times & springs unwound sort off. If this has happened it'll be obvious as the stop is likely split--but not common on older models. Happened to my 490 with the crap semi cast stop they used compared to stamped out steel of earlier yam's.
05 Mar 2019 16:31 #8
  • StukaGruppen13
Should have updated this a very long time ago, so anyone with a similar issue can use this as reference: my homemade gasket was too thick and was rubbing against the kickstarter shaft.
17 Mar 2022 05:48 #9
Haha, well there ya go. My notebook is getting fuller with problems solved that'll probably never happen twice.
17 Mar 2022 17:42 #10
