'74 DT175A Restoration
  • Nimajeb
  • Nimajeb's Avatar Topic Author
'74 DT175A Restoration was created by Nimajeb
Hello all,
I am new to the game and inherited this motorcycle that was sitting under a lean-to shelter for 20 years. It's in great condition regarding that storage but I'm starting to restore it. I am in Colorado North of Denver.
I don't know what I'm doing. I started with AI to get started. The kickstarter and pistons move. I cleaned the carburetor 5 years ago and will have to do it again I'm sure. I'll get a new battery but just wanted to see if y'all had any advice or directions to go to help a guy get started on this endeavor. thanks
22 Sep 2026 09:46 #1
Replied by pabdt on topic '74 DT175A Restoration
No battery needed except for brakelight, turn signals, horn, so shouldn't affect it running.
Pull plug and lay it against head, kick then check for spark while kicking. You can also pull the cover off left side and
turn it over w/drill, I believe a 19mm.  Once spark established, move on to fuel and air.  Remove homes built inside of air box and then all you have left is that carb hopefully.  There are other things to creep up, but thats a good start.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 22 Sep 2026 15:47 by pabdt.
22 Sep 2026 15:45 #2
Replied by MarkT on topic '74 DT175A Restoration
One caution.  It will run without a battery but it will likely blow any light bulbs that are on if you rev it much without a good battery installed.
23 Sep 2026 08:11 #3
