How to remove the passenger footpegs 1975 400??
  • TennesseeVol51
  • TennesseeVol51's Avatar Topic Author
How to remove the passenger footpegs 1975 400?? was created by TennesseeVol51
Both passenger footpegs on my dt400 are loose and flop all around and spinning all way around.
I do not like buddy pegs anyway is there any thing I’m missing, the only way I can see to remove them is to cut them off??
the tab on the swingarm is permanently riveted to the peg I’ve never seen this before.
why would Yamaha design the pegs not to be removed serviced or replaced?
here is a picture
imgur.com/gallery/buddy-peg-removal-1975-yamaha-dt400-bifRP5m
18 May 2026 22:48 #1
I have a feeling you're looking at someone's modification?
I certainly haven't seen everything and I don't remember everything I have seen.  I can say I don't remember ever seeing a Yamaha of this era with rear pegs that didn't attach to a threaded bung in the swingarm.  And I've owned and worked on a lot of them.
18 May 2026 23:12 #2
looks like you could tack weld that bolt frame to the peg frame to give you leverage and maybe it will unwind off the swingarm.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
18 May 2026 23:34 #3
Yes, and more pictures would help determine if this is some sort of "hack" or something simple like someone threaded them in without the jam nuts.
19 May 2026 06:27 #4
Agreed that it's threaded in without the jam nut and the threads are stripped, or the bolt is spinning in the bracket. Is the bolt head turning when you twist it?
19 May 2026 08:38 #5
  • Reed valve Richards
  • Platinum Member
  • Platinum Member
Replied by Reed valve Richards on topic How to remove the passenger footpegs 1975 400??
How to remove passenger foot pegs : 1. First remove the passenger... ;)
Yo Joe, Go Joe
19 May 2026 15:05 #6
  • TennesseeVol51
Replied by TennesseeVol51 on topic How to remove the passenger footpegs 1975 400??
imgur.com/gallery/dt400b-swingarm-remova...f-buddy-pegs-yZDomy6
I was removing the swingarm anyway.. everything on the swingarm came apart so easy.
 You can believe me or not but the swingarm bolt just pulled out easy as can be.
 And the inner bushing pushed out with my index finger.
then I put the swingarm in the vice and started trying to remove the pegs I tried the left side, mind you now the bolt on the backside of the swingarm that holds the chain guard came off like brand new.
 But the buddy peg was not gonna budge with multiple tries with propane torch and Kroil. So I put the cutting wheel on my die grinder and cut the rivets off the backside flush and did no damage to the frame I filed it off smooth and it’s perfectly flush so I will dab some paint and no one will know any difference.
 If I ever need the threaded holes I can drill the bolts out and clean the threads..
I’ve got a lot of cleaning to do more to come later and I know many more questions, thanks for everyone’s help
19 May 2026 20:58 #7
your link is messed up. a bunch of random pics comes up.  a tesla floating in a lake for one.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 19 May 2026 21:08 by pabdt.
19 May 2026 21:07 #8
  • TennesseeVol51
Weird when I click the link it takes me straight to all my pictures I’ve uploaded to Imgur
19 May 2026 23:54 #9
  • TennesseeVol51
19 May 2026 23:59 #10
