12 v battery for DT3 battery box
- hcdiiiga
12 v battery for DT3 battery box was created by hcdiiiga
I'm installing a Vape system on my Yamaha DT3. The battery box is 3" x 3". The instructions say not use lithium batteries. I can't find a 12 v battery which will fit in the box. I hate fashion yet another thing to install this system, is there a battery which fits the box?
Posted in the wrong place.
- buckstrucks
Replied by buckstrucks on topic 12 v battery for DT3 battery box
Look into sealed lead acid batteries used in security or UPS systems
- pabdt
Replied by pabdt on topic 12 v battery for DT3 battery box
Check out this
battery PDF
You may have to rotate it but its got F1 connectors and easy to work with.
DURA12-1.3F
DURA12-1.3F
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- tgill
Replied by tgill on topic 12 v battery for DT3 battery box
Hello, I'm not sure about the DT3 battery, but if you're looking to replace the battery on a '75-'76 DT 400 with 12v after installing a Vape ignition, there are sites on the net stating that the BS BT4B-BS or BS4B-5 battery fits.
It most certainly does NOT! Its 1/2" too long and will require battery box elongation.
28 Feb 2026 08:13
