DT 400 Dieseling
- tgill
Replied by tgill on topic DT 400 Dieseling
Sometimes I wonder if dropping a tooth on the drive sprocket would help, at least with the 5-25 MPH range. I have an MX400B that of course is geared way differently, that is a smooth as glass on the bottom end. Come to think of it, my DT1C and DT175E do as well.
01 Feb 2026 10:10
#11
- Schu
Replied by Schu on topic DT 400 Dieseling
Don’t let me discourage you from trying the drive sprocket change, but my 400 has a huge rear sprocket which gives similar results. It still has the bucking and chugging problem.
01 Feb 2026 10:47
#12
- AirborneSilva
Replied by AirborneSilva on topic DT 400 Dieseling
I did go up a little on the pilot jet for my DT400C, it helped some so I'll probably try going up a bit more.
01 Feb 2026 10:51
#13
Replied by MarkT on topic DT 400 Dieseling
Actually someone reported that going UP on the front sprocket helped. His theory, if I remember correctly, was that the taller gearing put more load on the engine during cruising which smoothed out the surging.
The following user(s) Liked this Post: Snglsmkr, AirborneSilva, Schu
01 Feb 2026 15:10
#14
