DT175 non spark
- budgie955
DT175 non spark was created by budgie955
Greetings all
im new to DT ownership and have bought a 1975 DT175B which isn't sparkling
I have done all the checks for coil ground kill and ignition switches etc but still no spark.
Digging deeper the stator has been replaced as the connector wire colours don't match. It connects as follows
From stator to main loom
Black to black and white
Red to green and red
Yellow to yellow
Green to green and yellow
No blue neutral switch wire present
My question is should it spark given how it is wired ?
And best way to test the stator please ?
Thanks guys
Regards
Dave Burn Sheffield UK
Yellow to yellow
Thanks guys
Regards
08 Jan 2026 02:23
Replied by Gr8uncleal on topic DT175 non spark
Not a direct answer to your question, sorry, but maybe have a look at Rex's and Vape sites, to see if the whole ignition system has been changed over for one of theirs. If it has, then a further internet search, or a direct request to the company, might produce the wiring set up instructions that you need.
Also, what markings are on the rotor and stator? Here is a link to a new original one in Australia, although the wiring might differ slightly from the one for US bikes.
GENUINE YAMAHA PARTS STATOR ASSEMBLY DT175FA 1974 DT175B 1975 458-81300-10 | eBay
- budgie955
Replied by budgie955 on topic DT175 non spark
Wiring is the same as mine
my flywheel is marked F140-04408
I'm hunting for resistance figures for the coils on the stator
I can't find a readable wiring diagram online
If any one can assist please do
08 Jan 2026 04:48
Replied by MarkT on topic DT175 non spark
Does the stator have points and condensor?
08 Jan 2026 06:51
- budgie955
Points and condensor yes
I have spoken to rex speed shop and they do a refurb service at a very reasonable price, worth talking to if anyone is looking for ignition systems
08 Jan 2026 10:38
- pabdt
Replied by pabdt on topic DT175 non spark
first I see poss of different plate. Is that the orig magneto on a diff plate? Matched pair?
as wired, it appears it would likely spark but I don't know what plate you have there. the black wire from stator plate has 3 connections for main harness. The rest are just lights or charging.
key switch, run switch R handlebar, primary side of coil. any of these are grounded and no spark is result.
a quick test I like is to spin over rotor w/drill and watch for arcing at points. when grounded, they won't arc. if they don't arc, unplug harness to localize and try again. If still no arc, check over points/condenser, magneto, woodruff key, etc. nothing wrong w/replacing 50 year points/condenser.
Black to black and white (primary of coil and also key sw and handlebar kill sw)
Red to green and red (when lights on, sent to white wire, rectified and charges battery)
Yellow to yellow (sent to headlight dimmer sw )
Green to green and yellow (same as green red, but lights off)
No blue neutral switch wire present (ground for instrument light, no affect on spark)
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- budgie955
So every coil is shorting and its expensive to repair all 3 ...does anyone know of another unit to try just to get the bike running ? Its points and condensor model .. The vape unit is available but they want 73 euros to ship
The engine is unknown so i just want to hear it run I see a DT100 unit on ebay at a good price, Would this work? Or could i fit those coils onto my back plate?
dave
dave
How have you determined every coil is shorting?
The following user(s) Liked this Post: RT325, pabdt
30 Jan 2026 09:07
Replied by RT325 on topic DT175 non spark
For spark black is the only one to worry about. Run that from the mag loom direct to the coil. Give points a scratch & be sure they have some gap. Then i'll bet "not much" she'll start right up. Could test the black with the points bridged with cardboard. Don't have much resistance, like under two ohms i think without looking. Lighting coils are earthed at the ends so all coils show resistance reading from each wire to the stator plate. I think even the ignition sourcy thing is earthed but internaly somehow into one lighting coil. Happy to be corrected as "75 model is a bit late for me. ps, call me old fashioned but i use an analogue meter as like to see that needle swing.
