1975 dt125 b frustrations
  • peggyma
  • peggyma's Avatar Topic Author
Replied by peggyma on topic 1975 dt125 b frustrations
so a bit of an update, installed autolite plugs gapped at .020, changed timing to 1.8 (.070) and no start, but it backfired a lot more out the exhaust! Sooo I put it back to 3mm, fired with a half kick.
Now here's what I noticed, I've fired it up cold a few times and even though sometimes it takes a few kicks but it does start and seems to run great, tuned the mixture screw a bit, idles nice, snappy response. Took it up and down the driveway a couple times , got the the farthest point and died of course, again almost like it ran out of fuel. Not an instant off like ignition shut down, just bog,bog,bog,died. Fired it up with some trouble got it back to garage.
When its warm, it is really tough to start, plugs wet, nice blue spark, kick and kick and a pop out the exhaust but no start.
Today I was thinking maybe a case leak or other leak when it heats up? So tonight pulled the motor and will pressure test soon. Thoughts on this??
05 Jan 2026 20:53 #11
  • pabdt
  • pabdt's Avatar
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 1975 dt125 b frustrations
There is a port on carb from inlet where fuel line is connected to the inlet valve. This port is known to get clogged up. IF your floats are correct and you have a fuel supply, this port may be blocked. At least sounds like you are running out of fuel after start up.
As mentioned, is idle fuel jet clean?
Also, is needle jet clean and small port in venturi behind slide open? Spray some carb cleaner w/that little red tube from inside the carb in to the hole. That is where the fuel mix exits. it is small and may be plugged up.
If you have an ultrasonic, give it a sonic cleaning. I think is too early to yank the engine, but don't me stop ya!
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
05 Jan 2026 21:58 #12
Replied by MarkT on topic 1975 dt125 b frustrations
I'm still wondering exactly where you found that 3mm spec, if you have the advance wedged open when setting, and how you're determining the piston position when setting timing.
Backfiring out the exhaust is usually retarded, not advanced and 3mm on that bike if you have decent compression will usually hole a piston under load.
The following user(s) Liked this Post: Swoop56, Snglsmkr, pabdt, Ht1kid
05 Jan 2026 23:23 #13
  • peggyma
So speaking of advance and retarted, I feel a bit of the last. The 3mm is the suggested roll back, I assume to get rid of any possible back lash, the to 1.8mm BTDC.
As per the instructions, find TDC, roll in opposite direction of normal travel,CW,3mm then roll in normal travel,CCW, to 1.8mm BTDC. At that point, points should be just open. I am using a dial indicator to find TDC and the continuity check on my multimeter to tell me when points are open/close and am holding advance weights open.
Even though I am sometimes clueless and have the timing wrong, could that induce the symptoms I have where it would not start after a warm up period?
Still egar to learn these 2 strokes and again would love to sort this out for my son and move on to a christmas project I recieved of a 1973 Kawasaki G4TR.
07 Jan 2026 17:02 #14
Did you ever connect your voltmeter to the battery and check the voltage with key on while trying to start?
On the battery models if the key got left on, sometimes the ignition coil fries and acts up.  Often it will even melt the plastic.
I think you said you "checked" the condensor but that would be the first part I'd replace with your symptoms, good battery voltage, and no signs of overheated coil.
07 Jan 2026 17:32 #15
  • peggyma
coil is new although aftermarket. Voltage when running was 12.8, maybe a tad low? I will replace condenser, I think there's a spare.
07 Jan 2026 17:37 #16
  • peggyma
What is the proper way to check a condenser?
07 Jan 2026 22:34 #17
There have been a lot of issues reported with aftermarket ignition coils.  Many are bad brand new.
They make condensor testers, I've never had one.  I replace.  I have had bad condensors allow the bike to start but backfire and not want to rev at all.
Your voltage is fine.
08 Jan 2026 06:48 #18
  • peggyma
Sooo, finally sorted due to a great find of a older vintage bike mechanic who still offers his services. Checked everything I have been checking but last thing was looking for spark under pressure. Plug laying on head, amazing spark, spark disappered at 30psi. OEM coil was installed and spark was good until 80psi. New points installed, spark all the way up to 125psi which is cyl pressure. Now as soon as you hit the start button, it fires and runs beautiful.
Aftermarket coil bought from a reputable supplier from the UK was ultimately the culprit.
Thanks everyone for all your input and suggestions!
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid, pahiker
20 Jan 2026 21:43 #19
Replied by Gr8uncleal on topic 1975 dt125 b frustrations
Was the supplier Yambits?
I know that it's very dangerous to generalise, but I will anyway! A lot of ignition faults nowadays can be traced to inferior repro parts - coils, points, condensers, plugs etc. Always go for original, or a reputable period aftermarket manufacturer, such as Daiichi.
Glad you got it sorted.
20 Jan 2026 23:58 #20
