DT175C change shaft
  • Schu
  • Schu's Avatar Topic Author
DT175C change shaft was created by Schu
Is this normal "change shaft" movement when the oil seal has failed?
Or do I need to do more than simply replace the seal?
youtube.com/shorts/mewFfp64CmU?si=40aTcuMTrEYkc-__
02 Dec 2025 08:43 #1
Replied by MarkT on topic DT175C change shaft
Unfortunately, "normal".  New seal won't fix slop. That 74-76 shift linkage design was not one of Yamaha's best.
You can still find NOS covers for a decent price sometimes, hole for stub shaft in case might be wallowed out too though.
02 Dec 2025 17:39 #2
  • Schu
Replied by Schu on topic DT175C change shaft
Thanks Mark. I’ll replace the leaking seal and keep an eye on it. My bikes don’t see much use, so it might be fine for a few years!
02 Dec 2025 18:46 #3
Replied by Mark350 on topic DT175C change shaft
Cannot that be bushed?
02 Dec 2025 19:26 #4
Replied by pabdt on topic DT175C change shaft
this might require a case split to set it up right, but I wonder if a steel FLANGED BUSHING would work. For example, ID of bushing close to shift shaft diameter, then OD = custom. To compensate for flange head, a 1mm or so thinner seal could be used.
edit: mark350, was thinking same.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 02 Dec 2025 19:31 by pabdt.
02 Dec 2025 19:29 #5
I'm sure it will be fine for a long time.  I don't know that I've ever seen one that wasn't worn?
I've packed the area under the shift sector cover full with thick grease and that seems to slow any oil leaks.
The following user(s) Liked this Post: pabdt, Schu
02 Dec 2025 21:09 #6
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
02 Dec 2025 21:17 #7
  • Schu
Thanks for the Facebook link pabdt. I was able to view it even though I am not a Facebooker. Once I read thru it I saw the next post which also interested me but then it asked me to sign in……. I have no plans to join Facebook, but my wife is on it so I will continue snooping on her account!
03 Dec 2025 07:53 #8
