DT175A / 1974 Exhaust options
  • tee_cee
  • tee_cee's Avatar Topic Author
DT175A / 1974 Exhaust options was created by tee_cee
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=365392763588&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by MarkT on topic DT175A / 1974 Exhaust options
Schu is probably the expert... rare to find a pipe for 74-75 but they did make them back in the day.
I found the ad on ebay for the 74-81...  it looks like a "monoshock" pipe to me...  78-81.  Not even close to the same as the 74-75.
There are some pipe builders that might make them... sometimes there's a local guy you can take the bike to but not sure how to find those guys.
There was a company in Texas...  Circle F I think...  that made pipes for some of the enduros and has the jigs for them.  I think they have a Facebook page.  Not sure if they're still around.
AMS Racing in Arizona caters more to vintage motocross but I spoke to them years ago and they gave me a lead on a 74 TS Suzuki pipe.
The following user(s) Liked this Post: tee_cee
03 Jun 2025 11:24 #2
Replied by Schu on topic DT175A / 1974 Exhaust options
It took me years to find a pipe for my DT175B but when I did it was the best I could ask for. It’s a J&R pipe that was never used. It came with the silencer and all the hardware. It even had the instructions and a J&R decal. But man was it expensive. I jumped on it immediately and have never seen one again.
The only other pipes I’ve found for the crossover style exhaust are for the bigger bore bikes and most of them are Bassani brand and they rarely have the silencer anymore.
I’d be interested in knowing the quality of the ones you had mentioned. It might be your only option. I have heard other people say the same as MarkT regarding Circle F still making pipes for some of the old enduros.
Good luck!
imgur.com/a/pvVGiIp
The following user(s) Liked this Post: Ht1kid, tee_cee
03 Jun 2025 18:13 #3
Replied by RT325 on topic DT175A / 1974 Exhaust options
Many years ago when i used to ride a CT1 to work i fitted what was by memory a through the frame MX175 exhaust. I had to modify it to go straight along like earlier models did. But man did it wake it up & about doubled the top end power & revved out of sight, not that you had to, was good all the way building stronger as the revs rose. Was back in the days at work when we'd get the redundant stock list once in a while & pretty much fighting over stuff haha. Would have been in the twin shock MX175 so much like your DT175A "74 frame i'm guessing--lot of guessing as 40 odd years ago.
04 Jun 2025 17:49 #4
Replied by Wrench66 on topic DT175A / 1974 Exhaust options
Since the DT175A and B are siblings to the MX125/175 variant of the same years, one of their pipes (as well as the YZ125A-B ) should slip right on through. The frames are nearly identical save for a few items but that should be an easy way to pump up your DT .
-- Ray
Nothing makes me smile like the smell of Blendzall green label ;)
Last edit: 06 Jun 2025 00:19 by Wrench66.
06 Jun 2025 00:18 #5
