1976 DT175 clutch plates/fibers order
- goatboy56
1976 DT175 clutch plates/fibers order was created by goatboy56
I am almost sure that I have seen here (I think from Mark) that the manual is wrong and that I should start with a fiber and end with metal.
PO has it starting with metal and ending in fiber. Also if the rubbers are there I will remove them.
Thank, John
Thank, John
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
01 Mar 2025 08:32
- 1975175B!
Replied by 1975175B! on topic 1976 DT175 clutch plates/fibers order
Why remove the rubber cushions?
01 Mar 2025 08:36
Replied by MarkT on topic 1976 DT175 clutch plates/fibers order
In 1976 I believe they had the "toothed" pressure plate that engages the hub. On those later models, stack can end with a fiber.
The early models needed the steel last.
01 Mar 2025 09:01
Early model pressure plate with no splines to engage hub that should have a steel last.
Later style with splines (arrow) that does not need a steel last.
01 Mar 2025 09:11
- goatboy56
Replied by goatboy56 on topic 1976 DT175 clutch plates/fibers order
This is the pressure plate that is on there.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
01 Mar 2025 09:17
- goatboy56
Was doing this and then saw your photos after posting my photo.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
01 Mar 2025 09:18
Hmmm... Does your engine number have the "559" prefix?
I could have sworn that 76 was the first year 175 with the splines
01 Mar 2025 09:31
- goatboy56
As for the rubber cushions it seem that the consensus is not to use them. Not sure why.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
01 Mar 2025 09:31
- goatboy56
Yes 559 both frame and engine. Not sure about what PO did as it was about 80% restored and passed away and bought from family member. It did not have an oil pump and I have been able to get everything needed for the 559 and now installing that and it was a little hard shifting so that's why looking at clutch while it's open.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
01 Mar 2025 09:36
The rubbers can swell and/or harden (or not get installed right) and can cause slippage.
I'm fairly certain that's not a 559 pressure plate. Strange.
01 Mar 2025 09:43
