sequence to rebuild the thermal phase shocks cylinder
- Gerryz
sequence to rebuild the thermal phase shocks cylinder was created by Gerryz
Hi there! Can anybody help with the sequence to rebuild the cylinder of the thermal shocks?
imgur.com/a/TuzN0rV
I lost the screw which holded together all the small parts :( The other shock is completely rebuilt.
imgur.com/a/TuzN0rV
Replied by MarkT on topic sequence to rebuild the thermal phase shocks cylinder
Here's a diagram from the service manual of the oil flow on compression and rebound. Maybe it will help? There have also been threads on here showing rebuilding if you do a search. (Sometimes called "thermal flow")
22 Feb 2025 13:05
Here's one of the threads.... has a lot of pictures.
www.yamaha-enduros.com/index.php/forums/...hock-rebuild?start=0
22 Feb 2025 13:12
- Gerryz
Replied by Gerryz on topic sequence to rebuild the thermal phase shocks cylinder
Thanks! Found a picture an will check on monday how it will come together...
22 Feb 2025 13:28
