Bottom end
- Albycliff
Bottom end was created by Albycliff
Good morning/afternoon from Australia. I recently purchased a 75 Yamaha dt400. The crankcase has a nasty hole in the bottom. It came with a crankcase marked IR9-00552 from what I gather this is a later single shock dt400( but could be well wrong) but wondering if it the same as the 501 marked case in all aspects other then the markings? Kind regards Alby.
03 Feb 2025 20:57
- Albycliff
Replied by Albycliff on topic Bottom end
*I've only seen one mention of IR9 being from a later dt400, so not sure if it is. At a glance it looks like.
03 Feb 2025 21:09
Replied by RT325 on topic Bottom end
By memory the clutch actuator changed from underneath to on top on later 400's.
04 Feb 2025 02:16
Replied by MarkT on topic Bottom end
1R9 is a euro spec DT400 monoshock (aka "DT400MX" outside the US)
The clutch actuator RT325 mentioned is a major difference that I agree exists between the earlier twin shock and the later monoshock 250/400's.
04 Feb 2025 04:27
- Albycliff
Thanks to both of you for sharing the knowledge.i appreciate it. I have a motorcycle swap meet, this weekend hopefully I can find something there.
04 Feb 2025 05:46
- Albycliff
Appreciate the help and time. Much appreciated.
04 Feb 2025 05:47
