Replacing clutch cover
  • john.lockwood5@bigpond.com
  • john.lockwood5@bigpond.com's Avatar Topic Author
Replacing clutch cover was created by john.lockwood5@bigpond.com
I need to replace the clutch cover on my DT360a.
I have a nos cover, kick start oil seal, gaskets for the cover and the oil pump and gearbox oil.
Is there anything else I need?
Anything I need to be careful about?
Is it easy to remove and refit the oil pump?
This is my first attempt, so any helpful suggestions would be greatly appreciated.
thanks
John
27 Jan 2025 01:28 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic Replacing clutch cover
 from near Salisbury, UK.
If your model is like other Yamahas, then you shouldn't need to actually remove the oil pump - it should lift off with the cover. However, there might be one or two cover retaining screws under the smaller cover, alongside the oil pump.
Check out the Tech Library to see if there is a service manual for your bike.
27 Jan 2025 02:21 #2
Replied by RT325 on topic Replacing clutch cover
There will also be a seal for the oil pump drive shaft that fits on the inside of the case. #4
images.cmsnl.com/img/partslists/yamaha-d...gyau1065c-3_45bd.gif
27 Jan 2025 04:01 #3
Replied by Schu on topic Replacing clutch cover
You may need an impact driver to break loose the side cover screws. If you don’t already own one, then do yourself a favor and pick one up. One of the handiest tools in the box.
Edit:
I am referring to the type you whack with a hammer to break the screws loose.
The reference to impact driver is often mistaken for an impact gun.
The hammer type impact driver is much more affordable.
Last edit: 27 Jan 2025 09:28 by Schu.
27 Jan 2025 07:08 #4
  • Gr8uncleal
"You may need an impact driver to break loose the side cover screws. If you don’t already own one, then do yourself a favor and pick one up. One of the handiest tools in the box."
Good advice.
Also, if screws are still fitted (as opposed to allen bolts), make sure that you use a JIS screwdriver, not Phillips.
The following user(s) Liked this Post: MarkT, AirborneSilva, Ht1kid
27 Jan 2025 07:18 #5
Replied by DEET on topic Replacing clutch cover
The main thing that could potentially cause you a problem is:
Aligning the end of the oil pump drive shaft with the slot in the crankshaft when reinstalling the cover.
The following user(s) Liked this Post: RT325, Gr8uncleal, Ht1kid
27 Jan 2025 09:37 #6
Just my opinion but I only use an impact driver when necessary. I generally use Tbar with a new sharp correct size inpact tip in the Tbar. Give it tap to seat it then twist. I might tighten them up the same way or just with a new #3 screwdriver but I don't impact to tighten. I guess some use an air or battery impact gun though, but everyone to there own. I also grease the new cover gasket because with my luck I'd need to remove the cover again before long haha. Important too what DEET said re aligning the pump drive shaft flats with the crank slot.
Last edit: 27 Jan 2025 13:37 by RT325.
27 Jan 2025 13:34 #7
Replied by MarkT on topic Replacing clutch cover
I think the "impact driver" being referred to is the good old fashioned hammer-driven kind that came with JIS bits.
"Vessel" was the brand (made in Japan) that came in the little tin box with bits here in the USA...  a lifesaver for removing crosshead screws that seemed to strip out so easily if you tried to use the "Phillips" drivers we had in the USA.
You can still buy Vessel drivers new and the vintage kits in the tin boxes can often be found on ebay fairly cheap.
27 Jan 2025 14:18 #8
Replied by john.lockwood5@bigpond.com on topic Replacing clutch cover
Thank you one and all.
RT325, thank you.
Do you know when undoing the oil pump mounting bolts and removing the pump, does the drive shaft and collar come out with it, leaving the oil seal in the cover?
If so, do I just need to fit an oil seal to the cover?
27 Jan 2025 22:13 #9
RT325, thank you.
Do you know, when undoing the oil pump mounting bolts and removing the pump, does the drive shaft and collar come out with it, leaving the just the oil seal in the cover?
If so, do I just need to fit an oil seal to the new cover or should I obtain the collar as well?
Any other suggestions ie how to line up the drive shaft with the crankshaft slot etc?
I tried the bolts in the existing cover, all come undone easily
27 Jan 2025 22:22 #10
