Testing charging coil 1974 DT Enduro
- Joefox90
Testing charging coil 1974 DT Enduro was created by Joefox90
Hello all, I’m looking for guidance on how to test my charging coil on my 1974 DT 250 my question is can I test the coil off the bike or does it need to be on the bike?
Which wire do I test with the positive side of my meter?
What Ohms reading am I looking for?
What Ohms setting does my meter need to be on?
Regards Joe
Regards Joe
02 Sep 2024 11:58
Replied by MarkT on topic Testing charging coil 1974 DT Enduro
Best place to start is the Yamaha Service Manual in the Tech Library here.
02 Sep 2024 12:24
- Joefox90
Replied by Joefox90 on topic Testing charging coil 1974 DT Enduro
Hi thank you I've looked on here I can only find how to test coil whilst engine is running I'm hoping you can test the charging coil of the bike with a meter
02 Sep 2024 12:36
You didn't look hard enough. The Yamaha manual should answer all of your questions.
yamaha-enduros.com/index.php/service-man...ctory-service-manual
Yes, they have "engine running tests" but if you keep reading they have the resistance checks you're asking about. (page 125 of the manual)
02 Sep 2024 12:44
- Joefox90
Thank you so much your help and knowledge is very much appreciated kind regards Joe
02 Sep 2024 13:07
Replied by Ht1kid on topic Testing charging coil 1974 DT Enduro
Greetings from Tennessee
02 Sep 2024 15:34
Replied by RT325 on topic Testing charging coil 1974 DT Enduro
Welcome from NZ. Here's a screen shot link of the page you need.
But personaly i like to just test it running,
Not that i know what those reading should be but if there's more output than the lights need & leaves enough to raise the votage on the battery then must be good. I'm guessing a bit that the green/red is a higher daytime output for the battery charging side but happy to be corrected.
Not sure if those ran a single wire regulator to save the bulbs in the case of an empty battery or battery removed but its a good idea to have one regardless.
It's very low resistances you're looking for & i don't know how far from those determine if faulty hence as i say, i like to run it & see!!.
photos.app.goo.gl/GNHfMWxiKY637oR47
Pic is a bit blurry sorry.
Do you have a particular issue you're trying to track down?.
